Old 12-10-2007, 12:47 AM   #21
cyanide-is-a-way-out
cyanide-is-a-way-out is on a distinguished road
ya when i ordered my lexus afm it also came with the sensor not just the metal housing
cyanide-is-a-way-out is offline   Reply With Quote
Old 12-10-2007, 03:39 AM   #22
Spudboy
Spudboy's Avatar
I guess I'll check around other sources. It would seem getting a new sensor too would make more sense.
Old 12-10-2007, 08:57 AM   #23
west_side_supra
west_side_supra's Avatar
yea cyanide knows what i'm talkin about, he's seen my car. just take a look around, ebay is your best bet though.
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 12-14-2007, 04:08 AM   #24
Spudboy
Spudboy's Avatar
So back on the injectors, this one site I went to talks about top feed vs side feed. I thought we had top feed? He wrote me...and also check this link and give me your opinion...please...thanks in advance.
Fuel Injector Clinic:Toyota Top Feed
The injectors listed below are all low impedance/peak&hold top feed injectors so you will have to convert to a top feed fuel rail to run them. This is typically less expensive than purchasing side feed injectors, since those are scarce and expensive. Also, once you have converted to a top feed fuel rail, a lot of other injectors will fit if you upgrade to the next level.
We sell a kit with 6 x injectors, a fuel rail, fuel pressure regulator and all the bungs and harness pigtails starting at $710.00.
550cc good for 360 wheel hp or 425 crank hp
650cc good for 425 wheel hp or 500 crank hp
750cc good for 485 wheel hp or 575 crank hp
850cc good for 550 wheel hp or 650 crank hp
950cc good for 620 wheel hp or 725 crank hp
1050cc good for 680 wheel hp or 800 crank hp
1150cc good for 750 wheel hp or 880 crank hp
Old 12-14-2007, 08:28 AM   #25
west_side_supra
yes we have top feed, as for the numbers for hp and crank hp i dont know how accurate that is, maby for those injectors though. again i highly recommend the PTE or RC injectors. they are the best your going to get. as for size i recommend 550cc - 780cc
fidenza cam gears
Old 12-16-2007, 05:32 AM   #26
ethan12510
ethan12510 is on a distinguished road
how much hp and torque would adding the 550ccs and the lexus AFM give u?
ethan12510 is offline   Reply With Quote
Old 12-17-2007, 08:49 PM   #27
west_side_supra
not any clue at all, i saw it as more of a supporting mod for your other motor work.
fidenza cam gears
Old 12-17-2007, 08:58 PM   #28
Spudboy
Spudboy's Avatar
Yes, supports other mods. Check this link for good info.
RC Fuel Injection
550cc injectors frostburn MKIII Supra 1 08-18-2008 04:46 AM
550cc and lexus afm supradrift MKIII Supra 2 07-02-2007 10:58 AM
550cc rx7 high impedance injectors? Suppra Girl? rnoswal MKIII Supra 9 05-03-2006 01:36 PM
