#11 |
Question, before goin with all these complicated procedures, did u check the most simple thing? IE. ur throttle body adjuster screw? maybe its keeping the Throttle body a little too open :P
as for your clutch problem, if its feeling spongey, you should get a new clutch, less you wanna do more damage to your flywheel... just my 2 cents
86.5 Toyota Supra ((Current Mods)) : -Slotted/Crossdrilled Rotors -K&N Filtercharger -H4 Projection light Conversion -Magnaflow Catback Exhaust -=Mods to do=- : -Rust Repair -Bodykit -Paintjob -Engine work -Suspension -Wheels -Intake (Semi-Done) -Exhaust |
#12 |
so i found some holes in the hose that comes off the idle control valve and i thin this is what is causeing it, what do u think
#13 |
Probably, replace the hose and see what happens.
MK3, Auto, Turbo. |
Thread Tools | |
Display Modes | |
high idle | 3.0trd | MKIII Supra | 4 | 04-27-2008 03:37 PM |
annoying high pitch squeal at idle | oowee623 | MKIII Supra | 2 | 06-04-2007 03:02 AM |
'92 7MGTE- high and unstable idle | liona | MKIII Supra | 7 | 02-04-2007 03:18 AM |
High idle | nickvash0104 | MKIII Supra | 21 | 07-13-2006 05:14 AM |
