Old 10-12-2007, 09:54 PM   #1
suprabahamut
Default help with engine removal
hey guys can any one guide me to remove what is left to pull the engine out. I have disconcted all electrical, fuel, and a/c lines and the power steering. the only thing that is left is the bell housing to the transmission,and one engine mount left. I have got 3 bolts from the bottom of the bell housing. with the replacement engine I see there is about 9 bolts can some one guide me how is the best way to get to the last of the bolts and get the engine mount on the intake manifold side out.
Old 10-13-2007, 06:13 PM   #2
kwnate
SP58GT
Save yourself some time and pull the tranny out with the motor.
Nate
Old 10-13-2007, 07:26 PM   #3
suprabahamut
I was reading about that I always thought it was harder to pull the tranny with the motor. so what do I need to disconect to pull the tranny.
Old 10-14-2007, 03:32 AM   #4
kwnate
SP58GT
Disconnect the speedometer cable under the car, drain the fluid, remove the shifter, trans crossmember (and ground) exhaust hanger. You can disconnect the driveshaft in the middle and remove it or let it slip out as you pull the motor forward.
Nate
engine removal mizuboi MKIII Supra 11 06-10-2011 06:25 AM
engine removal issue :\ xs87supra MKIII Supra 3 10-10-2006 07:44 AM
Engine removal questions... Suprapowaz! MKIII Supra 5 02-23-2006 04:46 PM
Removal of ENGINE and transmission GreenChevelleSS MKIII Supra 8 02-10-2006 06:10 PM
