Old 10-12-2007, 12:12 AM   #1
supraman121
Default 5spd to a 6spd
Would the 2jz 6spd trans work with the 7m if i were to use the 7m bellhousing?
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 10-12-2007, 02:57 AM   #2
kwnate
Do you know the mk 4 6 speeds go for $3,000 and up?
Nate
Old 10-12-2007, 03:55 AM   #3
supraman121
Would it work?
K&N Air Filter
Old 10-12-2007, 04:27 PM   #4
86_sports_1jz
86_sports_1jz's Avatar
86_sports_1jz is on a distinguished road
no it won't, different bell housings and tranny won't fit in as a direct drop. much fabbing is needed
GOVERMENT APPROVED HIGH SPEED VEHICLE
86_sports_1jz is offline   Reply With Quote
Old 10-13-2007, 11:55 PM   #5
Chambers
Chambers's Avatar
Post
Well it will fit without modding the tranny tunnel, its the shifter linkage that has to be modified, other than that only tranny mounts are needed, but the bell housing on the Getrag is one with the tranny, so it cant be adapted to a 7M bell housing.
"Stuck in the 80's"
Who much is worth a 2JZ-GTE + Getrag 6spd JayMark Non-Generation Specific Questions 3 03-06-2008 02:26 AM
5spd conversion tokis MKIII Supra 3 11-25-2007 03:26 AM
