Old 10-12-2007, 02:19 PM   #1
87 Supra
87 Supra's Avatar
87 Supra is on a distinguished road
Default stripped rear end bolt
Ok I’m in trouble with my Supra right now. The rear end has been singing so I’m swapping it out with one from my parts car. All the bolts are out but one. It’s the driver side cross member bolt that’s nearest to the driveshaft. This dang thing is stripped in there. Not rounded off mind you. This thing turns and turns but wont come out. It loosened up just a bit and that it. The other bolt just like it came out from the other side with some good rust on the first part of the threads. I’m guessing this thing is the same but worse. I put a crow bar on the rear end to pull it down and hopefully allow the threads to bite but no sale. It’s a big a$$ bolt too. Any ideas? I dont want to drill it... its a monster.
87 Supra is offline   Reply With Quote
Old 10-12-2007, 05:35 PM   #2
f00g00
It sounds like the nut broke from its mounting and is spinning freely. iirc its mounted in the tubular frame of the car. Only solution is to get access to the nut to hold it with something.
Old 10-12-2007, 05:47 PM   #3
87 Supra
87 Supra's Avatar
I dont think i can access it. Its in the sub frame.
Old 10-13-2007, 11:52 AM   #4
IHateHacks
IHateHacks's Avatar
If you have access to a decent air compressor you can die grind the head of the bolt off.
Old 10-15-2007, 05:27 AM   #5
mrnickleye
mrnickleye's Avatar
or buy a high speed 1/4" electric drill motor.
Old 10-16-2007, 02:40 PM   #6
87 Supra
87 Supra's Avatar
Well I got her back on the road this Saturday. The nut was spinning so I cut it off and beat it back through the hole. Welded in a new nut and she’s good as new. Thanks for al your advice!
A Little Story about a crank bolt abhattan MKIII Supra 17 03-28-2013 01:06 AM
Rusty Rear Wheel Arches Bill UK Non-Generation Specific Questions 1 01-21-2007 10:07 PM
Broken Bolt scruffboy Non-Generation Specific Questions 6 10-31-2006 01:33 PM
