Old 10-13-2007, 08:58 AM   #1
colin172
colin172's Avatar
colin172 is on a distinguished road
Default Brake Fluid Dot 3 or 5.1
My brake fluid needs topping up as it is down to the minimum level. It says in the owners book use only Dot 3 but this is no longer available according to my local Toyota garage. They now only sell Dot 5.1. Can I use this in my '89 Supra?
colin172 is offline   Reply With Quote
Old 10-13-2007, 03:56 PM   #2
redmaro
Yes they still sell Dot 3, go to your local Checkers or Autozone.
MK3, Auto, Turbo.
Old 10-16-2007, 03:19 AM   #3
jfunez
jfunez's Avatar
i thought dot 5 is sinthetic and cannot be used or mixed with dot 3..it will destroy your brake system....dot 5 if im not mistaken is only used in motorcycle brakes...
Old 10-16-2007, 11:48 PM   #4
btwilson86
Super Moderator
btwilson86's Avatar
I'm not sure what vehicles use DOT 5; my 07 Kawasaki uses DOT 4
Old 10-17-2007, 12:07 AM   #5
twerb089
twerb089's Avatar
twerb089 is on a distinguished road
race cars and motorcylces use dot 5 i think.
get dot 3 or 4. i got castrol LLMA and i love it
1989 supra turbo automatic soon to become a manual
K&N, megan dp, gutted cat, 2 1/2" magnaflow cat back
NA intake cam, shimmed actuator
no A/C or P/S, therefore no ac condensor, compressor and no ps pump or resivior.
gutted interior, 4 tweeters, 2 kicker 12"s powered by an MTX 400W 350rms and an audiobahn 400W 300rms
twerb089 is offline   Reply With Quote
Old 10-17-2007, 02:23 AM   #6
mirage83
Here's a pretty good link on the subject...
http://www.motorcycleproject.com/mot...rakefluid.html
Old 10-17-2007, 10:44 PM   #7
supradrift
supradrift is on a distinguished road
if your car has abs do not use dot 5. whatever is in dot 5 ruins the abs control module
supradrift is offline   Reply With Quote
Brake Bleeding Woes... Lunch2000 MKIII Supra 4 09-11-2007 02:18 PM
losing brake fluid oowee623 MKIII Supra 3 08-07-2007 04:44 PM
Brake Fluid Reservoir igosaur MKIII Supra 2 06-28-2007 10:55 AM
Maintenance brake and clutch master cylinder fluid IHateHacks MKIII Supra 1 04-18-2007 07:15 PM
Wilwood MKIII Rear brake kit ARZ Arizona Performance 0 03-16-2007 07:46 AM
