what to do now?
i need some help with my apexi S-afc and HKS EVC XI " the new one" tuning
first of all as you all know i'm doing a rebuild. main info on the fuel system: -------------------------------- 550cc procision tune walbro 255lp lexus maf Turbo: ----------- Garret T70 Gt46 : Compressor Wheel - .66 A/R, 48.9 trim Turbine Wheel - 1.05 A/R, 61.9 trim 4.25" inlet, 3.38" outlet T4 flange with V-band first to start do i need a adj. fuel pressure regulator since i have the 255lp lexus MAF and 550's? second. does anyone know what percents of fuel change i should run with the s-afc? third EVC, what should i set it up as for amount of boost for what RPM, Turbo is capable of 35lbs of boost and 1000hp, but as for breaking in the motor i shouldnt run probably any higher than 6-8 lbs of boost right? also i have some fidenza adj. cam gear what degree do you recommend? oh and my friend wants to know why he is stupid enough to work on it :P for more info on the build and list of parts check out my previous post |
any ideas of what should set the fuel to? set the cams to? what i should set my boost levels to?
for boost just breaking in boost "city driving" no faster than 30MPH then highway settings for 60mph - 80mph after my 3-4 oil change and 200 miles.?.?.?. i already have a adj fuel pressure reg coming from www.suprasport.com. the full complete install kit. what should i set my pressure level to? |
| All times are GMT. The time now is 09:00 PM. |
