-   -   Crankseal Removal (http://www.toyota-supra.info/forums/mkiii-supra/9981-crankseal-removal.html)
teedoff00 10-19-2007 07:09 AM
Crankseal Removal
Hey guys, recently figured out that my oil leak is coming out of my brand new crankseal (less than 3500 miles) so I need to pull it and put in a new one. Does anyone have any info on the best way to do it without the Toyota SST 09308-55010 since the timing case is still installed to the block? Tools that were effective in removing these seals? Thanks in advance.
mrnickleye 10-20-2007 12:31 AM
FAQs section...timing belt at home
-using the coat hanger (or you may need to pry with a screwdriver), pop out the crank seal
