Old 02-09-2008, 03:54 AM   #1
marmlr339
marmlr339 is on a distinguished road
Default top speed limiter removal?
is this possible and if so, how is it done. all responses appreciated.
marmlr339 is offline   Reply With Quote
Old 02-09-2008, 10:18 AM   #2
On a US-spec Mkiv TT, it's easy. Just remove the traction control fuse.
MKIV.COM
(the oem traction control system kind of sucks so it's double-win)
On a euro-spec, I believe it's a little more difficult. From what I understand, you need to purchase a speed limiter removal 'black box' from HKS:
HKS Speed Limit Defencer (Type I)
Old 02-10-2008, 10:19 AM   #3
marmlr339
alright. do u know about an australian model. a non-export one. (not limited to 180km/h, instead limited to 250km/h). would that be the same as the us-spec tt one?
Old 02-10-2008, 11:09 PM   #4
Honestly not sure. US-spec limited to 155mph.
Old 02-11-2008, 12:25 AM   #5
marmlr339
i'd say its the same as the us-spec one then. is there any reason why it is limited to 155mph / 250km/h anyway? maybe so it's harder to over rev / blow / damage the engine??? thnx anyway
Old 02-11-2008, 02:27 PM   #6
I suspect it's related to insurance rates and/or import regulations...
Old 04-21-2008, 01:20 AM   #7
phokur
phokur's Avatar
phokur is on a distinguished road
also if your US MKIV is a NA, there is no sensor iir. the engine is the speed limiter ^^
phokur is offline   Reply With Quote
Old 05-25-2008, 06:38 AM   #8
marmlr339
Default it is
mlrmartinreilly339@hotmail.com
y do you want it?
Is this true? Fuse removal can change limiter jdbones Non-Generation Specific Questions 0 12-30-2007 10:31 AM
Speed limiter cut greddy defender old dude MKIII Supra 5 04-08-2007 07:48 PM
how do i derestrict my speed limiter? mohamed MKIV Supra 2 04-06-2007 12:04 PM
greddy speed limiter cut FullOfProblemsMKIII Non-Generation Specific Questions 3 04-07-2006 03:28 PM
speed\cruise control limiter removal The_Black_Beast MKIII Supra 4 03-13-2006 10:20 PM
