Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIV Supra > MKIV FAQ
Old 03-21-2010, 05:53 PM   #5
matt1993supraTT
matt1993supraTT's Avatar
matt1993supraTT is on a distinguished road
I live near Atlanta.
Note that the advanced, sophisticated ABS system is one of the things that make the MKIV TT a great GT sportscar, and a significant part of why it was very much worth the $50K price tag at the time (note: it's about an $80K sportscar in todays' dollars if you adjust that '93 price tag for the rate of inflation). Unless your Mkiv TT Supra is going to be a dedicated, trailered dragstrip-only car, the only tips you should be looking for is how to put the ABS back in your car, imho. In other words, there's a good reason why you're not finding any tech articles on how to remove the ABS - because it's generally a very bad idea.
well the car is going to be a dedicated track car, right now i am on a budget so i'll be using the stock turbos for awhile i was planning on running a adjustable proportion valve
matt1993supraTT is offline   Reply With Quote
Toyota Prius: midsize miracle silly Off Topic Forum 5 07-31-2006 07:20 AM
Test-drive the 2007 Toyota FJ Cruiser at Route 22 Toyota silly Off Topic Forum 1 07-07-2006 07:07 PM
2006 Toyota 4Runner silly Off Topic Forum 1 07-07-2006 06:52 PM
