Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIV Supra > MKIV FAQ
Old 06-06-2007, 07:38 AM   #11
sks
sks is on a distinguished road
I would also add that proper cooling modifications will be required if one has a FMIC - power steering cooler and oil cooler, the former being the most imperative.
With respect to methanol, how long can you run it on the track before it runs out?
sks is offline   Reply With Quote
Old 06-06-2007, 08:27 PM   #12
Jasin
Jasin is on a distinguished road
10-30 laps Depending on the PSI im running (the higher the psi the more i use)
Jasin K
Jasin is offline   Reply With Quote
Old 06-07-2007, 09:01 PM   #13
sks
Jasin K
Wow, where can I learn more information about your setup? Email? thanks
Old 06-08-2007, 10:41 PM   #14
Jasin
my setup changes alot due to the fact im playing with cams/meth water Ratios/injectors ect. but my e-mails jasonstatic@gmail.com
Old 04-27-2009, 06:51 AM   #15
supraman911
supraman911's Avatar
supraman911 is on a distinguished road
Keep your TT!
1.1995 Toyota Supra TT
2.Toyota AE86 Trueno
3.Mazda MX-5
4.Mazda RX-7
5.Mitsubishi Lancer EVO X Ralliart
LOVE these CARS
supraman911 is offline   Reply With Quote
looking to get a supra jslice13 MKIV Supra 13 09-03-2008 04:31 PM
Supra Mkiv Single Turbo 71GTS .81 A/R SupraTT/Iceland Show n Tell 14 12-16-2006 01:59 PM
Did they make an original single turbo supra (1994)? ts1994 MKIV Supra 3 07-20-2006 08:18 PM
