Old 06-26-2006, 03:57 PM   #1
Magical Trevor
Magical Trevor's Avatar
Magical Trevor is on a distinguished road
Default Questions about the oem fuel system
New here with some questions...
A little background on me and my car, I've owned 1 turbo car, and that's my WS6. I basically had to learn everything that I could about the forced induction world through trial and error, that being said it's got a 402ci (6.6L) stroker and a PT88 with all the suporting mods making a little over 920/900 on 20psi.
I've done as much searching as I could and I couldn't come up with some solid answers.
From what I've read the stock bottom end is extremely durable and that might be an understatement, I've also read that the stock twins are good for around 550-600rwhp.. or I might be a little off?
My main concern is the fuel system, at what RWHP do you need to start worrying about the fuel pump/lines/injectors/rails? Also about what psi (I know psi is relative, but I don't know how well the 2JZ's flow compared the the LS1's) can the stock fuel system take with 91-93 octane?
Sorry for all the questions, just trying to do some research and gain some knowledge before I go out and buy a Supra. (BTW I got my first ride in a supra. My friend has a t78 single and I was more than impressed!)
-Trevor
1998 Formula WS.6
2006 GSX-R 1000
Magical Trevor is offline   Reply With Quote
Old 06-27-2006, 02:03 AM   #2
Magical Trevor
No one knows?
1998 Formula WS.6
2006 GSX-R 1000
Old 06-27-2006, 09:09 AM   #3
That's a little off. The stock twins are good for about 375rwhp-485rwhp, depending on whether you're running an auto or 6spd...and the current state of the turbos & engine (i.e. wear & tear, mileage, maintenance, etc.).
If you get the injectors cleaned and flow balanced, with a brand-new fuel pump, the oem fuel system is good for about 550rwhp (absoluate max) through a 6spd, or 515rwhp through an auto.
You'll also need to run race fuel or meth injection for any boost level above 16psi on 93 octane. This is not dependent on the fuel system...it's dependent on the oem ecu's timing curve and a simple boost vs. octane caculation. In other words, even if you had 1000cc injectors installed, you still wouldn't be able to boost more than 16psi on 93 octane pump gas.
P.S. I only check the forums about once a day, so please bear with me if I don't respond immediately. You can also try emailing me at pwpanas@comcast.net.
Old 06-27-2006, 12:10 PM   #4
Magical Trevor
Thanks man, you answered everything I needed to know. If I have any other questions I'll shoot you an email...
1998 Formula WS.6
2006 GSX-R 1000
Old 08-19-2007, 01:22 PM   #5
bahsupra
bahsupra is on a distinguished road
Default J Spec Supra
Hello Guys, i am new here and i am new with my 94 supra. i am having a problem with starting the car, i was troubleshooting and i found the fuel pump not working, i conected it direct and the car started nicley, one more thing 5 day before the problem the car dosent go after 3000 rpm today after i connected the pump directly it was exellent.. so please can you guys send me the wiring digram for a 94 supra j spec. thank you.
bahsupra is offline   Reply With Quote
Old 08-19-2007, 03:39 PM   #6
bahsupra
hello, can i get the wiring digram for the fuel pump mkIV supra please. thank you
Old 08-19-2007, 03:49 PM   #7
Yep, you can get that and all other wiring diagrams for the car in the TSRMs. Here's an electronic version, but it's only there as a 'teaser' to encourage you to purchase the paper copy (along with the other TSRMs (engine, chassis) that you should have handy whenever you work on your Supra):
http://www.mkiv.com/manual/1995_elec...ual/index.html
Old 08-19-2007, 04:40 PM   #8
bahsupra
Thanks alot.....
Removing carbon canister, fuel evap. emissions pdogg Non-Generation Specific Questions 2 09-17-2008 06:58 AM
550cc west_side_supra MKIII Supra 27 12-17-2007 08:58 PM
tein flex or fuel system west_side_supra MKIII Supra 8 04-22-2007 11:01 PM
FUEL SYSTEM DEVILDOG Non-Generation Specific Questions 2 03-14-2005 06:57 AM
