#21 | |
Supra Owner
![]() Quote:
Oh, btw I found a picture for you that shows that the TRD Twin comes with its own flywheel (referring to your question earlier in this thread): http://www.trdracing.com/supra/_pu_twin.html
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 11-11-2006 at 02:10 PM. |
#22 | |
![]() Quote:
Thanks, Mike |
#23 | |
Supra Owner
![]() Quote:
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. |
#24 | |
![]() Quote:
I have installed the clutch and flywheel, that you have reccommended and have found that the gears are very stiff now, and the clutch is very high, i.e. it is very jerky when i drive it.... is this normal, until i break it in. The garage advised me that there is around 8mm of play in total between the fork, Slave and Master cylinder, would this have anything to do with it. Also they were saying that the Standard Flywheel was completely flat but this lightened one concaved in on one side, would this also make a difference?? cheers T |
#25 | |||
Supra Owner
![]() Quote:
#26 | |
![]() Quote:
They said they had to adjust it slightly. I took it to a local garage. No i bought the 'RPS Cyn-R-G Segmented Flywheel for 1993-98 Supra TT, the one you suggested, and since this is specifically designed to fit the Supra TT, i don't really see why there should be a problem. The flywheel they were talking about was the orginal "stock" one. Would you recommend that i change the fork 1st and see how it is, and then perhaps the Slave and Master if need be. cheers T |
#27 | ||
Supra Owner
![]() Quote:
![]() Which Ashford do you live in? CT? WV? AL? If you're interested, I may be able to recommend an experienced supra mechanic or owener(s) that you can get in touch with. Quote:
If you have the TSRM, you could try adjusting the clutch pedal yourself. It's pretty easy mechanically speaking. It can be done with one 12mm wrench...but you need the TSRM to make sure you do it right, since adjusted wrongly it can cause your throwout bearing to wear out very quickly. When properly installed & adjusted, there should be absolutely zero "play in total between the fork, Slave and Master cylinder". When properly installed & adjusted, the engagement/disengagement point should not be "very high". P.S. Your earlier post said that the lightnened flywheel is "concaved in on one side". Again, this could possibly be a problem, depending on which "side" they're talking about. Imo, if the shop suspected there was a problem, they shouldn't have installed the flywheel.
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 12-04-2006 at 01:01 PM. |
#28 | |
![]() Quote:
Hey, I spoke to Dusty at MVP Motorspoorts last night, who was very helpful. He advised that when you change/ upgrade your clutch, they can simetimes become stiffer, however that there should not be any sort of play with regards to the fork etc. He said at 1st try putting it into 2nd then 1st and this should make 1st gear easier to go into and the same applies for reverse. Also he was saying the generally Spring plated clutches are installed in a different way to the stock clutch, i.e. the opposite direction to which a stock plate would be fitted. But said that's how RPS clutches are fitted, but that they don't really deal with Southbend clutches, so that may not be correct for them, but generally they do fit in the opposite direction........Do you know if this is true or not??? Yeah if i had a choice i would of taken it to a Supra garage, or at least a garage with some sort of experinence in performance cars, but i was limited in choice, and most specialists are too far away, especially with me having to tow the car to them! I actaully live in Ashford in Middlesex in the UK, im sure if i was in the US i would of found loads of specialist garages..... Dam the UK.. ha ha! Cheers T |
#29 | ||
Supra Owner
![]() Quote:
#30 | |
![]() Quote:
Yeah i think i'll call southbend back again as the 1st time the guy was not very helpful, saying that its fits the same way as all other clutches.... i reckon he just couldn't be bothered to explain. The reason we don't know if it is installed properley is beacause no instalment instuctions were provided with the package when delivered! |
Thread Tools | |
Display Modes | |
Edo Performance Party and Car show (SoCal) | promark | MKIV Supra | 0 | 05-27-2008 09:56 PM |
HElp with sports clutch!! | whitequasimodo | MKIII Supra | 3 | 05-07-2008 11:06 PM |
choosing performance clutch | 88_supra | MKIII Supra | 1 | 02-05-2007 10:02 PM |
