Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIV Supra > MKIV FAQ
Old 11-10-2006, 08:30 PM   #1
Dom
Dom is on a distinguished road
Default Bcc
just worndering what are the advantages of fitting a greedy bcc ,is it worth while doing ,any opinions on this
Dom is offline   Reply With Quote
Old 11-11-2006, 02:01 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
All on it's own, the BCC won't do anything at all for your Supra. With no other modifications, it'd be a complete waste of $ and time. On the other hand, IF you're planning to do another modification to raise your Supra's boost level above about 14psi, then a BCC will be extremely useful. A properly installed & configured BCC eliminates the oem fuel cut that would prevent your Supra's boost level from exceeding 14psi. So...you asked if it is "worth while doing" and the answer is "yes" only if you are also planning to raise your Supra's boost. You also asked for "any opinions on this"; unfortunately I can't provide you with any opinions, only cold, hard facts and a link. j/k lol
Life begins at 30psi.
Old 11-11-2006, 04:56 PM   #3
Dom
thanks phil
