Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIV Supra > MKIV FAQ
Old 04-03-2009, 04:28 AM   #11
jza80rz
jza80rz is on a distinguished road
Just count the flashes, as it describes in the tech article:
"The diagnostic trouble code can be read by the number of blinks of the malfunction indicator lamp when TE1 and E1 terminals on the data link connector 1 or 2 are connected. When 2 or more codes are indicated, the lowest number (code) will appear first. "
i dont have the data link?
jza80rz is offline   Reply With Quote
Old 04-04-2009, 01:30 PM   #12
pwpanas
Supra Owner
pwpanas's Avatar
If you've got an mk4 supra, you've got a data link connector. It's below your steering wheel, partially under the dash, to the left (on us-spec mk4s).
Life begins at 30psi.
Old 04-05-2009, 02:48 AM   #13
jza80rz
I know but i dont have the "thing" to plug into it so i can read the codes... nor can i get my hands on one.
Old 04-06-2009, 11:43 AM   #14
pwpanas
Supra Owner
pwpanas's Avatar
You don't need to plug a "thing" into it. Just bridge the two pins indicated with a wire or a paper clip! That's what the article means when it says:
"2. Connect terminal between TE1 and E1 of data link connector 1 or 2."
(if you needed an OBD-reader, the article would probably have mentioned that. )
Old 04-15-2009, 01:41 AM   #15
jza80rz
ok i connected the terminals up and ran a diagnosis.. the result was weird:
i was expecting all those lights would blink etc but it didnt, that problem has pretty much gone away for a while now.
however just yesterday a different light came on it was the engine warning light.
so yeh i ran the diag and the engine warning light blinked in this sequence
( blink - blink blink blink ) and yeh kept repeating that, should i have waited longer?
so what sthe problem?
Old 04-18-2009, 01:03 AM   #16
pwpanas
Supra Owner
pwpanas's Avatar
Looks like you have a code 13. Did you look that up in the tech article?
Old 04-18-2009, 03:00 AM   #17
jza80rz
yeh i did, i didnt know what i could do about it though.. then the next day the light dissapeared never to be seen again.. all this stuff is starting to annoy me.
Old 04-19-2009, 04:16 PM   #18
pwpanas
Supra Owner
pwpanas's Avatar
Engine codes will disappear when they no longer occur (they still stayed stored in the ecu though).
Car owners that don't have the patience to methodically go through the troubleshooting steps usually end up taking their cars to a mechanic to get work done. On the other hand, if you're interested in learning how to do all of it yourself, we'll get you pointed in the right direction...
Old 02-10-2011, 10:47 PM   #19
Piggy808
Piggy808 is on a distinguished road
sorry I know this is an old thread...I only got the O2 sensor error code...cleaned the connector and that was fixed...i replaced the sensor anyway lol...so now the CEL just blinks at me...but the car bogs at lower rpm...no real improvement to the car...do I have to clear the ecu codes?
Piggy808 is offline   Reply With Quote
Old 02-11-2011, 12:51 PM   #20
pwpanas
Supra Owner
pwpanas's Avatar
No, something is still wrong with your car - that's why the CEL is blinking. Based on the symptoms, I'd guess a boost leak in your intercooler piping.
Engine light and warning light on. Chomper MKIV Supra 11 07-18-2008 11:44 AM
check engine light suprakid91 MKIII Supra 0 10-19-2007 07:33 PM
Check Engine Light Johnny boy 82 MKIII Supra 2 06-09-2006 09:41 PM
check engine light ironcobra2002 MKIII Supra 4 11-05-2005 04:07 AM
1998 Supra Check Engine Light SupraLady Non-Generation Specific Questions 2 12-15-2004 11:39 PM
