#8 | |
Supra Owner
![]() Quote:
The taillights will show a fault if a bulb is burned out, or if the bulb used is the incorrect resistance. Don't clear the code(s) - these are the keys to fixing the underlying problem(s). Tell us what the code number(s) is/are that you get, and we'll help figure out the problem. Most likely it's not related to the fluids or plugs...
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. |
Engine light and warning light on. | Chomper | MKIV Supra | 11 | 07-18-2008 11:44 AM |
check engine light | suprakid91 | MKIII Supra | 0 | 10-19-2007 07:33 PM |
Check Engine Light | Johnny boy 82 | MKIII Supra | 2 | 06-09-2006 09:41 PM |
check engine light | ironcobra2002 | MKIII Supra | 4 | 11-05-2005 04:07 AM |
1998 Supra Check Engine Light | SupraLady | Non-Generation Specific Questions | 2 | 12-15-2004 11:39 PM |
