Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIV Supra > MKIV FAQ
Old 10-12-2009, 05:26 PM   #11
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by RZ-rix View Post
I'm looking for a new set of rims because my older work rims have a offset of +47 on the front which wont probably clear a big brake upgrade package, so does anyone here have any sugestions on what offset is possible for larger calipers such as the brembo or stop tech brakes?
What is the diameter of the rims you're currently running? If they're 18" or more, they'll very likely clear most big brake packages.
Also note that you could shim the rim if nececessary - hub-centric shims come in various thicknesses and are a viable solution. For example, I had my oem rear rims widened from 9.5" to 11.5" and I ran one-inch thick shims, bolted to the hub. Each shim came with its own studs, which the wheel bolted on to (the holes in the shim for the oem studs were in between the shim's studs).
http://www.mkiv.com/techarticles/par...ned/index.html
Life begins at 30psi.
Old 10-12-2009, 05:33 PM   #12
RZ-rix
RZ-rix is on a distinguished road
Default rims
Currently I have 18x9 front and 18x10 rear. my supra is a J-spec TT , which comes with the normaly aspirated brake set up. Theres barely any room between the brake calipers and front rims.
Im thinking of installing the north american style TT Supra brakes, not sure if its a good idea or should I just buy brembos or Stop techs?
RZ-rix is offline   Reply With Quote
Old 09-29-2011, 04:59 PM   #13
87hilux7mge
87hilux7mge's Avatar
one thing i havent seen being considered in this thread, is inertial weight.
remember, his application is road racing. so just weight and width alone are not the only factors.
a wheel that has more hub-centric weight, could weigh more than another wheel, yet still get up to speed (so to speak) faster.
vice versa, a wheel that has most of its weight toward the drop center and rim lip, will take more effort to get rolling, but be easier to control and keep momentum up in an application like road racing, where he will almost be constantly moving.
and depending on restrictions for his races, he may not need an intensely wide wheel if he gets the proper tires. applying the power to the ground is imperative on tire selection. you can have 335mm tires, and still not grip or handle for beans. while you can have a 275-295 width tire that would give you superior handling.
just some thoughts. everything else thats been brought up was farely spot on.
in my research, fikse wheels has a great selection of light, wider and weight balance. there are others, but like i said, my research lead me to fikse.
GL!
Old 01-25-2013, 08:02 AM   #14
Suprastudy
Suprastudy is on a distinguished road
Question
Yes. Be sure to check the rim diameter you need to clear the brakes. Next, check the sizes of the tires that you plan to purchase and use. You may not be able to get near-optimal 275s or 285s in the front, and 315s in the rear. Maybe you'll end up with 265s up front, and 295s or 305s in the rear instead. Also have one or two back-up tire brands/models in case the company stops producing your first choice. Lastly, get the rim widths to match the rubber you'll be running. When you come close to your decision, please feel free to post here, and we'll provide feedback.
Low profile, wide front tires will give you a MUCH more responsive turn-in. You'll be shocked when you switch from oem 235s to 275s or so up front. Of course, it'll be a bit harder on your power steering, so be sure to follow proper maintenance, and use good fluid (eg Redline Power Steering Fluid).
Hypothetically, if you widened the back tires, and kept the oem front tires the same width, it'd push in the corners (i.e. turn-in would be less responsive). That's why you have to upgrade both the front and the back widths simultaneously and proportionally.
I fully agree with pwpanas serves on point with the info.I am currently deciding to go with 9 x 19 with a +43 offset front wrapped in 265/35/and rear 11.5 x19 with +44 offset with 305/40/19 problem is I don't know how this will look nor how much body modifications I am gonna face.Any help?
Suprastudy is offline   Reply With Quote
Old 03-22-2013, 10:23 AM   #15
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Suprastudy View Post
I fully agree with pwpanas serves on point with the info.I am currently deciding to go with 9 x 19 with a +43 offset front wrapped in 265/35/and rear 11.5 x19 with +44 offset with 305/40/19 problem is I don't know how this will look nor how much body modifications I am gonna face. Any help?
I can't answer to the offsets without going thorough some calcs. I'd recommend you have the company or person you purchased the rims from to guarantee fitment...especially proper clearance from the suspension (but not too much!). The wheel/tire should actually touch on the oem suspension when the car is up on jackstands and the wheels are hanging down as low as possible. With coilovers, there is still a tiny bit of clearance when the wheels are hanging at their lowest point.
However, I can tell you about the body modifications. Actually there is only one modification: Just get a reciprocating saw or a jigsaw and cut the rear fender inner lips. Tape it off beforehand so the paint is protected. Go over it afterwards with a grinder to ensure no sharp edges. Spray paint it afterwards so it doesn't rust. Done. I've done it dozens of times on Mkiv Supras, and the fender is no weaker than before...and you can barely tell its been modified unless you know exactly what you're looking for. Done right, and with the right offsets (I'd recommend +50mm for 11.5" width rims) 315mm width rubber fits perfectly with no rubbing at all (assuming stock-ride height suspension).
A few more details on the cutting process itself:
Basically you will cut a smooth line from the body joint in front of the rear tire to the back of the rear tire, over the top (of course). You want to trim away as much as possible (really!) - there shouldn't be more than 1/8" left of the lip on the extreme inside (when you curl your fingers around and feel downwards from the top). Across the bottom edge will be closer to 1/4" or so. Of course, there is no change at all to the outer (painted) fender. This nearly complete lip removal maximizes the clearance for the tire as it moves up and down with the suspension.
  • From the starting point at the body joint, do a relatively sharp curve to that max lip cut width
  • Follow that max lip cut width *straight*, up and over all the way to the back joint
  • do a relatively sharp curve back out to the opposite body joint
  • It helps to draw a line on the tape that you used to protect the paint (eg. with a sharpie)
  • Be sure to angle the reciprocating saw's blade slightly so the tip of the blade doesn't hammer into the inner fender (at a point beyond the lip) and keep that angle consistent throughout the cut.
  • Again, be sure to go over it with a grinder to round off the sharp edges, and then primer+paint afterwards.
  • Take a look at the attached pic for reference.
Got it? If not, please post or PM me with any questions.
Oh, here's what not to do:
  • Don't try to"roll" the fender lip. The fender lip much too stiff and will distort the fender if you try (yes, even with an expensive fender rolling tool).
  • Also, don't try to cut the lip with any sort of grinding wheel or dremel. This puts too much heat into the fender and will (likely) discolor the paint. Even with a reciprocating saw the fender will get quite hot - if you have a buddy helping you, you can keep the paint cool with wet rags while you cut with the jigsaw or reciprocating saw.
Old 08-17-2013, 07:47 PM   #16
ttsupramiv
ttsupramiv is on a distinguished road
hi pwpanas, my set up for my mk4 tt 6 spd.
front: 18x8.5 + 45 ( 245x40x18 )
rear| 18x10.0 + 50 ( 295x35x18 )
it that good? or bad?
thnx.
ttsupramiv is offline   Reply With Quote
Old 08-30-2013, 12:23 AM   #17
pwpanas
Supra Owner
pwpanas's Avatar
thnx.
I'm sorry to say that I don't really consider that much of an upgrade over the oem rims. The oem rims are 8" wide in front and 9.5" wide in the rear. If you're going to spend the $$$ on aftermarket rims, why not go with something substantially bigger? I consider 9.5" wide in front and 11.5" wide in the rear to be a bare minimum. With fender flares (eg. Veilside) you can run even wider rims.
What is your horsepower spec? If you're still running the oem 320rwhp with the oem twin turbos (i.e. not BPU, etc.), then perhaps those rims really are okay...
OZ Racing Wheels for Toyota Supra...... Codyjamesuno Parts For Sale 2 05-27-2014 04:16 AM
Tires Rubbing lazer371 MKIII Supra 10 11-19-2012 03:22 PM
Installing New Tires w/ Bad Rack & Pinion? sd88supra MKIII Supra 3 06-15-2012 05:35 PM
MKIV TT Wheels and Tires - Peoria, IL - $550 obo supra_91 Parts For Sale 0 05-11-2012 02:29 AM
Wheels, wheels, wheels... Caithness MKIII Supra 1 02-24-2006 02:13 AM
