Old 12-27-2007, 07:05 AM   #11
ethan12510
ethan12510 is on a distinguished road
toyota red dosent pit the head for example
ethan12510 is offline   Reply With Quote
Old 12-27-2007, 04:16 PM   #12
pwpanas
Supra Owner
pwpanas's Avatar
The green junk doesn't pit the head either, at least not while the silicates are still suspended in it.
By the way, isn't the pitting you mention exactly the same as corrosion? In other words, isn't your post redundant with the post I made prevously? If not (i.e. if you do have additional information to share, please explain. Not trying to be a dick, but what's the point of lots of posts all saying exactly the same thing? Is there any difference that you know of when you compare "it also dosent pit" with corrosion? If you do have any new/unique/original information to post, please do.
Life begins at 30psi.
Egr Cooler, Coolent Banjo slader99 MKIII Supra 6 05-02-2008 06:20 PM
1JZ-GTE 2.5 TT Overheat megawatts Non-Generation Specific Questions 0 08-28-2006 09:13 PM
