Old 01-19-2008, 05:51 PM   #1
ELGatoLoco
ELGatoLoco's Avatar
ELGatoLoco is on a distinguished road
Default single turbo
Do you know where i can find a Install diagram, so i can install one of theses things in my supra? I'm buying one from ebay, and i'm sure that it doesn't some with one. And ideas?
ELGatoLoco is offline   Reply With Quote
Old 01-21-2008, 08:41 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Hmmm...honestly never worked with an ebay turbo kit. I'd recommend you don't get your expectations too high - it may not fit right. Hopefully you know folks that can weld/machine/port/etc it to work & fit correctly before you do your final install.
Alternatively, consider not buying the one from ebay, and getting a higher quality kit like HKS or Sound Performance...
Here's a write-up that you may be able to use...
Life begins at 30psi.
Old 01-21-2008, 04:21 PM   #3
ELGatoLoco
ELGatoLoco's Avatar
I have an non turbo supra. i noticed the port for the oil return but it is not open. What do i have to do to access it, is it just a punch out like a freeze plug or do u know. Also what fuel delivery mods do i need to do? All your info is much appreciated.
Old 01-23-2008, 04:47 AM   #4
pwpanas
Supra Owner
pwpanas's Avatar
The n/a isn't really suited for turbocharging, and requires a lot of mods in conjunction with the turbo addition. About the best advice I can give you is to save up for something like this:
Boost Logic Stage 1 NA-Turbo Kit :: Turbo Kits :: 93-97 MKIV Supra NA :: Toyota :: Boost Logic
HorsepowerFreaks Turbo M3 vs Single Turbo Supra ChrisB Non-Generation Specific Questions 0 01-01-2007 04:56 PM
Did they make an original single turbo supra (1994)? ts1994 MKIV Supra 3 07-20-2006 08:18 PM
