Old 04-22-2008, 01:50 PM   #11
bungeye
bungeye is on a distinguished road
all i really want is a kit that will give me boost level pretty much the same as a TT supra
bungeye is offline   Reply With Quote
Old 04-23-2008, 03:01 AM   #12
pwpanas
Supra Owner
pwpanas's Avatar
Boost Logic Stage 1 NA-Turbo Kit :: Turbo Kits :: 93-97 MKIV Supra NA :: Toyota :: Boost Logic
That kit will do exactly what you describe. At mkiv-tt oem boost levels (i.e. 11.5psi), you'll be pretty much matching the hp of a bpu mkiv tt.
Life begins at 30psi.
Old 05-13-2008, 08:12 PM   #13
Feel-IX
Feel-IX is on a distinguished road
hey pwpanas i was just wondering that link to the stage 1 turbo kit
the turbo in there the T61 its rated at 700 hp
um wouldnt that kill my engine?
the 2JZ is one hell of an engine! virtually indestructible
Feel-IX is offline   Reply With Quote
Old 05-13-2008, 11:28 PM   #14
pwpanas
Supra Owner
pwpanas's Avatar
I'd qualify that statement by reminding folks to always run a sufficient amount of octane to match your boost level. The 2jz is only indestructible as long as you obey this rule. If you don't (i.e. if you run too much boost for the octane level of fuel you have in the tank), you'll destroy any engine, regardless of how much $$$ you spend on the internals. Eg. With the oem ecu (i.e. with the oem timing curve), 18psi on 91 octane pump gas (US spec) will destroy the engine bit by bit. Detonation will gradually take small chunks of metal out of the pistons and head until compression is severely affected.
The story is actually more complex than that simple rule if you're running an aftermarket ecu (eg. AEM). You still have to observe the rule, but there is a bit more flexibilty if you can retard the timing curve.
Haha.....Read these Emails about SUPRAS FOR SALE Metalluthier Non-Generation Specific Questions 54 04-25-2011 11:51 PM
Supra's for a Decent price ! cageceo Off Topic Forum 4 07-16-2007 11:53 AM
New to Forum and to Supras Connvict Show n Tell 0 02-11-2007 11:38 PM
