Old 06-06-2008, 03:22 AM   #1
joemoua
joemoua is on a distinguished road
Default Motor Dies When Gas Is Not Pushed
Newbie here, but maybe some of you pros can help me out. Got a 93 that had been sitting for a year. When its started now, the engines cranks up and drives, but as soon as I completely let go of the gas, the engine dies. Any suggestion on what to check first.
joemoua is offline   Reply With Quote
Old 06-06-2008, 06:29 PM   #2
TomFraser
TomFraser is on a distinguished road
if it's a standard, it isn't stalling because you let go of the gas in gear... right? (you never know )
TomFraser is offline   Reply With Quote
Old 06-06-2008, 10:17 PM   #3
joemoua
well, lets assume that I knew how to drive a manual and would know the difference between letting off on the gas in gear. Could it be something in the injectors, or maybe the throttle? Any other suggestions?
Old 06-07-2008, 03:52 AM   #4
pwpanas
Supra Owner
pwpanas's Avatar
Is it a TT? Has it been modified or is it 100% bone-stock?
Just guessing without any other info, it sounds like it could be a boost/vacuum leak (assuming the gas in the tank isn't a year old).
Life begins at 30psi.
Old 07-06-2008, 04:55 PM   #5
whitetiger777
whitetiger777's Avatar
whitetiger777 is on a distinguished road
fuel ecu gone bad, try 12 volt mod....
whitetiger777 is offline   Reply With Quote
Old 07-07-2008, 05:07 PM   #6
pwpanas
Supra Owner
pwpanas's Avatar
Agreed, but only as a test. For a daily driver, the 12v mod isn't ideal.
