Newbie here, but maybe some of you pros can help me out. Got a 93 that had been sitting for a year. When its started now, the engines cranks up and drives, but as soon as I completely let go of the gas, the engine dies. Any suggestion on what to check first.
#2 | |
![]() Quote:
if it's a standard, it isn't stalling because you let go of the gas in gear... right? (you never know ![]() |
well, lets assume that I knew how to drive a manual and would know the difference between letting off on the gas in gear. Could it be something in the injectors, or maybe the throttle? Any other suggestions?
#4 | |
![]() Quote:
Just guessing without any other info, it sounds like it could be a boost/vacuum leak (assuming the gas in the tank isn't a year old).
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 06-07-2008 at 03:54 AM. |
fuel ecu gone bad, try 12 volt mod....
#6 | |
![]() Quote:
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. |
