Old 06-08-2008, 11:46 PM   #1
2jz conquest
2jz conquest is on a distinguished road
Default 1.5jz prospects, 2jz GE questions
Hello, I am in the process of building a 2jz powerplant for a project of mine. I have a 2jz GE out of a lexus SC300 that I got for free. The head gasket is blown and it has bent valves. I will most definately need to replace the head, so I was wondering if a 1jzGTE head will bolt up to a GE block? I know that a 2jzGTE head will not bolt to a GE bottom end, is this the same case with the 1jz head? Also, my pistons are a bit scored but not in horrible condition. I am also aware that the 2jzGE pistons don't respond to boost very well. What modifications are required to put GTE pistons in a GE block?
I would like to salvage as most of this 2jzGE as possible. I may just end up buying a 1jzGTE complete long block, but If I can use a 3.0 bottom end then I will.
Thanks for help in advance, sorry if I come off as a newb
2jz conquest is offline   Reply With Quote
Old 06-09-2008, 12:25 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Actually, a 2jz-gte head bolts to a 2jz-ge bottom end just fine.
Also, no modifications are required to fit 2jz-gte pistons into a 2jz-ge bock. Note however, that the 2jz-gte pistons will not be fully functional without the oil squirters that are present in the 2jz-gte block.
Life begins at 30psi.
Old 06-09-2008, 01:44 AM   #3
2jz conquest
From what I've researched so far, you need to drill out parts of the block for the studs to fit, is that accurate? If this is true, is the same modification required to fit a 1jz head on the GE bottom end?
What part of the GTE pistons won't function in a GE block without squirters? Would I have to worry about overheating the pistons without squirters, or are stock GTE pistons forged?
Old 06-09-2008, 02:45 AM   #4
pwpanas
Supra Owner
pwpanas's Avatar
No. The threaded holes for the head studs are exactly the same in the 2jz-gte and 2jz-ge blocks.
Sorry, I have no idea about a 1jz head.
As you already alluded to in your next question, it's the cooling.
Honestly, it depends how much boost/hp you're planning to run.
Toyota hasn't released the metallurgy for the oem pistons...but it's a well-tested/proven fact that, with together with the oil squirters, they will handle 1100+rwhp through a 6spd (using aftermarket connecting rods... Fyi,the oem 2jz-gte connecting rods are 'only' proven reliable to about 850-900rwhp through a 6spd).
Note - I'll be out of town for a few days, so pardon the intermittent responses...
Questions before buying a Supra proximityburn MKIV Supra 5 08-15-2008 02:09 AM
Questions about the oem fuel system Magical Trevor MKIV FAQ 7 08-19-2007 04:40 PM
Need your gus help- a few questions ravenmaster MKIII Supra 10 10-21-2006 09:59 PM
new here, few questions SoooopRa! MKIII Supra 6 08-29-2006 11:25 AM
newbie questions erik MKIII Supra 4 01-10-2006 11:37 AM
