Old 06-20-2008, 04:18 PM   #1
jslice13
jslice13 is on a distinguished road
Default looking to get a supra
so i'm looking to either get a stock single or stock twin turbo supra but im not sure which one i want right now. eventually i would like to upgrade it to around 600rwhp or slightly more and im wondering whether the single turbo or twins would be better for this. also, is this amount of horsepower still ok for daily use? thats what i was hoping for with just casual streetracing. which one would be easier or cheaper to upgrade? from what i read i think the stock twins bpu would bring it up to around 400 horsepower but what about the single? i also think the stock tt is good for up to the horsepower im eventually hoping for but is the single turbo? last one, is buying a stock single turbo cheaper, on average, than a stock tt?
jslice13 is offline   Reply With Quote
Old 06-21-2008, 12:07 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
There's no such thing as a stock single mkiv. Sorry. They're all either twin turbos or non-turbo.
Also, the stock twin turbos won't do 600rwhp, so you'll be looking at a single turbo upgrade kit.
Yep 600rwhp is okay for daily use, as long as you run race fuel or meth injection.
The twin turbo (i.e. not the non-turbo) would be cheaper to upgrade to 600rwhp.
Yep the stock twins bpu+++ bring a 6spd TT up to about 400rwhp. With a single, the sky's the limit - 1500rwhp+ if you can afford all the upgrades (really!).
Again (since you asked the question twice), no the stock twins are not good to 600rwhp - where on earth did you hear that?
Again (since you also asked this question twice), there's no such thing as a stock single on an mkiv supra.
Since you can't buy a stock single turbo mkiv, for any price (since it doesn't exist), then I guess the TT is cheaper?
P.S. All of this info is REALLY easy to find if you read through the 'stickied' threads.
Life begins at 30psi.
Old 06-21-2008, 05:59 PM   #3
jslice13
thanks a lot for that information, appearantly i like to read false stuff on the internet so the stock twins would basically only be good for up to that 400 horsepower and after that you'd need to put in a single turbo kit right? and i guess the single turbo supras i was looking at i assumed were stock but clearly weren't. thanks again!!
Old 06-22-2008, 03:38 AM   #4
jslice13
what are some differences between the import twin turbo and usa tt supra? do the imports, from japan for example, have slightly less horsepower? i think it'd be sweet to have the right hand drive but is there many differences between them?
Old 06-22-2008, 08:22 AM   #5
pwpanas
Supra Owner
pwpanas's Avatar
Yep the japan imports have slightly less horsepower. The turbos, the intake cam, and the fuel injectors are slightly smaller in the j-spec. Other than that, no MAF, and the RHD thing, they're the same car.
Old 06-22-2008, 08:26 AM   #6
pwpanas
Supra Owner
pwpanas's Avatar
Actually, with a very low mileage mkiv tt (i.e. 30K miles or less), you can pump out 450+rwhp through a 6spd. It takes several other supporting modifications to achieve this (referred to as bpu++++). After that (anything over about 475rwhp through a 6spd), you need a single.
Happy to help
Old 06-24-2008, 12:49 AM   #7
jslice13
so does it end up being worth it importing a supra rather then buy it here if its just for mere fact its a right handed import? because to do the bpu would you have to get 'import specific' parts? also i think i read that the turbos (or something im not sure) were made of different material? if this is the case is it possible to use parts not imported on the supra? or would i have to basically import everything both cosmetically and mechanically?
Old 06-24-2008, 11:15 PM   #8
pwpanas
Supra Owner
pwpanas's Avatar
Yep the turbos are ceramic, which makes them slightly less durable, iirc.
Are you trying to convert RHD to LHD? If not, most 'bpu' parts for a LHD US-spec Mkiv Supra TT will fit a Japanese-spec Mkiv Supra TT.
Old 06-26-2008, 11:21 PM   #9
jslice13
ok so i guess it is possible to replace the ceramic turbos with the steel ones. also, do you know if this website would be legit and a good idea if/when i decide to buy a supra, possibly import? Toyota Supra - How to Import a 1993 Toyota Supra MKIV | MK4 from Japan to Canada
Old 06-27-2008, 03:27 AM   #10
pwpanas
Supra Owner
pwpanas's Avatar
I wouldn't recommend swapping out the ceramic turbos. Just drive the crap out of them, and upgrade to a single if/when you blow them.
Sorry I've never seen that website before. I will check it out though, and post back here if I find anything that's incorrect.
