Old 07-08-2005, 07:28 PM   #1
tytyguy
tytyguy is on a distinguished road
ok, so i am thinking about buying a supra this guy says, it was the se base model and he put a TT bottom end, with a NA head and The transmission is stock (auto ) . he says the new egine has 10,000 miles on it. and the turbos have the same. he wants to sell it for like 17000 or so. is this a good deal. or is that unsafe for the engine not to have the 2jz in it? or the regular non 6 speed trans? heres some pics.
http://jordan.catalysthost.com/95supra/
thanks for the help
tytyguy is offline   Reply With Quote
Old 07-11-2005, 01:31 PM   #2
JRLewis0550
JRLewis0550 is on a distinguished road
I would say yes and no, 1700 isnt a bad price also its a hard top very rare. It has had alot of money put into it, but im not so sure about the engine setup. I also bought an NA but mine was fully converted over with a JDM GTE. The only real problem you need to think about is the trans and the rear end. To convert it over with all new parts its like $10,000. That is only if you want a 313 rear end the rear on an NA is around a 4.10 if you know anything about rear ends. This means that with the NA rear your looking at being around 4000 RPM at 80 MPH. I dont like this set up so im installing the 6 speed and TT rear end. So it all depends on what you want, you could even pick up a GTE engine for about 3-4 thousand. Or look into getting a head and intake just some things to think about.
JRLewis0550 is offline   Reply With Quote
buying a supra, need help! 001100 MKIV Supra 4 08-03-2005 12:47 PM
Im New, Going from a V8 to a supra maybe? Help! Deadtoday Non-Generation Specific Questions 9 05-24-2005 11:10 PM
need help! supra running bad cuda/supra#1 Non-Generation Specific Questions 2 03-17-2005 10:50 PM
