#1 |
91 octane shouldnt have any bad side effects. its spec.
#2 | |
On a side note when I did have my ODO cluster off I noticed on the very bottom right hand corner of the ODO display was a burn mark from within the sealed plastic display. Looking through the side of it I could see an electrical component but I don't know what it is. *Edit: Took the car out for a test run this morning after the ODO wire fix. Cruise control works (just had to hold it down for about 5 seconds like you said). Active fron spoiler works automatically at 90km/h. Also I have not been able to reproduce the error 42 while going up hills or load driving . Now I just need to clean her up and get some new rubber stops for the hatch. The ones in there now are the originals and are old and hard and bumps make the hatch rattle.One question about the slip diff. (think its called TRAC in the USDM's). When I turn the ignition on for the telltale light test, I get two Lights related to slip diff. Slip On Slip Off When I push the button to turn the slip off the lgiht comes on which is good. When I leave slip on I don't get a slip on light though. Does this light only come on when the slip diff kicks in? Last edited by Durandal; 08-30-2008 at 04:22 PM. |
#3 |
hi, first off thank you to those whove taken the time to post this fix online.
I too have the following lights on. JDM twin turbo AT /!\ master warning - always on O/D off - off at start up, on flashing after couple blocks of driving slow speeds MIL engine check light - off after start up, on after reach prolonged highway crusing speeds or load. Traction control OFF - always on, no flash TRAC OFF - never on even at start up (!) hand brake light - ON always Just got the car, removed a speed meter/cut electronic device (left 2 wires connected to ECU but taped sealed open wire ends. Removed the turbo timer completely. Left the HKS fuel cut defenser. Cleaned up all taps that lead to open wires. It was a mess... The indacator module that reads ABS, TRAC OFF etc ... has been tapped from circuit to circuit frankenstein style. ABS, Oil level still comes on at start then off which is all I need from this module so I left it alone. But I suspect that's why the trac off is always off. I don't like to use this function anyways so no problem there. auto spoiler plug plugged in but no light. There was at one point, it flashed constantly as i have disconnected the auto spoiler. Dont use this so dont mind that it doesnt light up however i wonder if this hints to a problem area in the harness . did the diagnostic check. code 42. I did the pink blue/red wire splice procedure. AT fluids on mark at cold/hot. But the light still flashes. Car appears to be shifting fine ie no irratic searching. ODO appears to be counting. I have an aftermarket steering wheel that deletes the cruise control and SRS so no issues there. I've read all the posts on the internet on this issue. Still left with this question... If my tach and ODO and speedo are working normally. Then I guess the no.1 speed sensor is working. I'm terrible with the solder iron thus did the splice fix. Since this did not work, am I correct to assume the solder fix ( plus reverse splice fix) will not make a difference as well? I assume the master /!\ light is on because of the code 42 or is it off because of my traction control always off? Im not sure how this was achieved. Also interesting of note. There is no speed limiter on my car. I can easily pass the 180km/hr mark but no electronic devices found. 7.5 TRAC fuse is plugged in. But Traction Control OFF stays on, control buttom lights up but no response when pressed. Question: the pink wire feeds the odometer with the signal which is said to "buffer" or process this signal before it's sent back out via the blue/red wire out. So if this is spliced, then effectively a step in the process has been skipped. If this is true, than this means an incorrect or inaccurate signal is then sent out. Quite perplexed by this... this is the only reason i can think of that explains why my O/D is still flashing after the "fix" unless there's some other variable I haven't pinpointed yet. Thanks in advance. |
#4 | |
Supra Owner
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. |
#5 |
hey
so my trac slip light sometime flashes on my dash too and anyone know wut does that mean?? thanks
![]() HKS/GREDDY/SARD/CUSCO/VOLKS |
#6 |
The buffering I was referring to was mentioned here called wave form shaping.
http://www.mkivsupra.net/vbb/attachm...6&d=1234196778 |
#7 | |
Supra Owner
Based on this info, I'd now have to advise not to bypass the ODO; if re-flowing the solder joints doesn't fix the issue, then ideally the ODO should be replaced. However, if the ODO is bypassed, it's possible that the waveforms from the tranny speed sensor are sufficient to trigger the ecu a very high % of the time (wthout wave form reshaping by the odo)....
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 07-18-2010 at 03:02 PM. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Electrical Troubleshooting | go.stfu | MKIII Supra | 0 | 10-21-2007 09:32 PM |
| Clutch Troubleshooting | ivire | MKIII Supra | 9 | 11-09-2006 01:29 AM |
| fog light troubleshooting | SupraBoy | MKII Supra | 6 | 10-31-2006 09:07 AM |
| troubleshooting | wishesforjdmswap | MKIII Supra | 8 | 07-26-2006 07:09 AM |
| Electrical troubleshooting | claymore | Non-Generation Specific Questions | 2 | 04-17-2005 01:15 PM |
