Old 09-05-2008, 08:45 PM   #1
sloth
sloth is on a distinguished road
Default AC removal MKIV
Just thinking of removing my AC pump since my Ac doesnt work-previous owner hit a rabbit at high speed Ac radiator and coolant radiator were both damaged
since theres only 1 belt driving all the ancillaries if I remove the pump is there a shorter belt you can use?? any 1 know part manufactuer and part number?
sorry if this has been asked but I tried seach function codnt find what I needed
sloth is offline   Reply With Quote
Old 09-06-2008, 05:49 PM   #2
I've got a custom belt on my car, due to some aftermarket pullies. Basically you make all of the changes you need, and then put a string or thin rope around the pullies and measure it. Then you go to your automotive store and tell them you need a 6-rib accessory belt in the lenth you've measured. I know gatorback belt part numbers reflect the length in inches.
Old 09-07-2008, 06:29 PM   #3
sloth
sweet I will give that a go, sounds easy enuf
Supra or Bmw? Greglatta Off Topic Forum 90 10-07-2009 06:37 AM
Want to learn about the Mkiv Supra? pwpanas MKIV FAQ 6 09-06-2008 05:37 PM
