Old 09-17-2008, 05:48 PM   #1
lamw001
lamw001 is on a distinguished road
Default LF: Lightbulbs guide
Hi,
I recently acquired a JDM RZ and wondering if it uses different lightbulbs than USDM. Really appreciate if anyone can some knowledge about this. Any complete lightbulbs guide out there other than the Sylvania:
OSRAM SYLVANIA - Replacement Guide - Start
Thanks in advance,
Maverick
lamw001 is offline   Reply With Quote
Old 09-17-2008, 10:50 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by lamw001 View Post
Hi,
I found this info with a couple of web searches:
The correct bulbs for the J-spec plastic headlights (early and late model) are:
Low = 9006J
High = 9005J
The J variant of the bulbs are a different fit to the standard 9006/HB4 and 9005/HB3 bulbs. The 9005/HB3 bulbs will fit in place of the 9005J, but the 9006/HB4 bulb will not fit in the low beam (the diameter of the body of the bulb is too big). As an alternative you can use a 9005/HB3 bulbs in the low beam as well (note you will need to trim a rib on the connection with the harness so that they will fit, very easy to do), ie
Low = 9005HB3
High = 9005/HB3
Bulbs & Lights Toyota tail lamp lh 81561-14700
Bulbs & Lights Toyota tail lamp rh 81551-14700
Bulbs & Lights Toyota t/s lamp frt rh 81510-80086
Bulbs & Lights Toyota t/s lamp frt lh 81520-80086
Bulbs & Lights Toyota t/s frt harness 81515-14390
Bulbs & Lights Toyota turn signal/hazzard flasher 81980-12070
Bulbs & Lights Low Beam Headlamp 9006
Bulbs & Lights High Beam Headlamp 9005
Bulbs & Lights Parking Light 168
Bulbs & Lights Front Turn Signal 1156
Bulbs & Lights Rear Turn Signal 1156
Bulbs & Lights Tail Light 1157
Bulbs & Lights Stop Light 1157
Bulbs & Lights Fog/Driving Light H3-55w
Bulbs & Lights License Plate 168
Bulbs & Lights Backup Light 1156
Bulbs & Lights Front Side Marker 194
Bulbs & Lights Rear Side Marker 194
Which light bulb(s) are you looking for?
Life begins at 30psi.
Old 09-18-2008, 02:23 PM   #3
lamw001
pwpanas, THANKS, you are great! This is a very useful information.
I am not particularly looking to replace anything. However, I do want to go over all the bulbs as the JDM ones in general may have lower outputs. (learned it from previous R32) So I want to update them to USDM standards or maybe LEDs too. Regardless, it's a 15 years car and I'd love to freshen it up and keep it mint. Little projects for the winter anyway.
Thanks again,
Maverick
my new polishing guide zooloo Exterior , Interior, and Detailing 7 11-15-2019 01:37 AM
Super Monitor Install Guide ravenmaster MKIII Supra 10 03-11-2008 01:03 AM
