Old 04-25-2009, 01:24 PM   #1
Curtis
Curtis is on a distinguished road
Default Quick question
Hi i'm new here and a have a quick question for you,
the other day i was reading that the mk3 supra's mainly govern at 250km/h
and the right hand drive cars all govern at 180km/hour because japan had a cap on them or something.
Is this ture, and if so does it apply to MK4 supra's?
they.call.me.curtis
Curtis is offline   Reply With Quote
Old 04-25-2009, 09:47 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Yes, MK4s are electronically limited to 155mph. However, this is easily bypassed in US-spec MK4s by pulling the trac fuse.
Life begins at 30psi.
Old 04-25-2009, 11:05 PM   #3
Curtis
Okay cool, im looking at an Mk4 1993 with 78 000 km 2jz non turbo for $9000, worth it?
they.call.me.curtis
Old 04-26-2009, 12:44 AM   #4
pwpanas
Supra Owner
pwpanas's Avatar
For what it's worth, imo, I'd never buy a non-turbo. It's nowhere near the car that the TT is - pretty much every component is downgraded except the chassis itself.
Old 04-26-2009, 05:54 PM   #5
Curtis
Yeah i see what you mean, i can always buy a single turbo for it. And its a 2jz, so great potential right?
It's an automatic btw, want the link?
they.call.me.curtis
Old 04-27-2009, 09:22 AM   #6
pwpanas
Supra Owner
pwpanas's Avatar
The 2jz-gte and the 2jz-ge are similar engines, but they are not the same. The non-turbo ('ge') version has higher compression pistons (which is bad for forced induction), a completely different cylinder head, and no oil squirters to cool the pistons. Add that to the fact that the entire abs braking system, transmission, differential, ignition, ecu, suspension, etc., etc. on the non-turbo mkiv is all downgraded. Without a huge investment, it'll never be anywhere near what you'd get if you'd start with a tt in the first place.
Quick question 88ProjectSupra MKIII Supra 1 04-24-2008 11:56 PM
quick question need answered quickly switchblade Non-Generation Specific Questions 5 07-21-2007 12:47 AM
Quick Question SUPRA18 Non-Generation Specific Questions 1 02-15-2007 02:07 AM
New here, quick question on possible lean issue adamsbomb MKIII Supra 6 02-13-2007 04:42 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
