Old 05-07-2009, 07:19 PM   #1
mrbean
mrbean is on a distinguished road
Default Engine dies while driving
1995 na standard, all stock, has died twice (a month or so apart) at 10-20mph. seems like it has happened right after shifting (into neutral). all warning lights come up, steering locks. i have been able to restart on 1st try and everything works as normal. anyone had this happen before? would like to troubleshoot b/c it's obviously dangerous if your car just dies. any thoughts before i take it in would be greatly appreciated.
mrbean is offline   Reply With Quote
Old 05-07-2009, 09:29 PM   #2
dunewarz
dunewarz is on a distinguished road
I don't have, own, or know much about the model car but it might be the idle speed control value not opening. Probably due to it being dirty or faulty.
Not even sure if it has a iscv but something similar.
dunewarz is offline   Reply With Quote
Old 05-09-2009, 08:02 PM   #3
pwpanas
Supra Owner
pwpanas's Avatar
I know the TT has an iacv, but not sure about the n/a.
Life begins at 30psi.
Old 05-10-2009, 11:43 PM   #4
suprabahamut
I have never myself had a car where something like this happens, but a friend of mine has. Check your alternator, change your fuel filter it could be clogged if you have not already, it could be a fuel pump starting to go. or bad plugs or wires. My friends car was a automatic Mazda 626 and it was her alternator but it might be different with your car. Some body like Mr. Nickeleye might be able to help you he is a supra specialist and I think a Toyota certified mechanic he is the man with these cars. When you do find the problem, post it I would like to find out what it was.
Old 05-11-2009, 12:41 PM   #5
mrbean
thanks for responses. i'll let you know what comes of it.....
Old 05-11-2009, 07:25 PM   #6
Curtis
Curtis is on a distinguished road
I hope it's not your oil pressure, it could be dying if you have no oil pressure.
Hopefully its not the problem or your looking at some problems.
they.call.me.curtis
Curtis is offline   Reply With Quote
Old 05-12-2009, 10:46 PM   #7
therippr
therippr is on a distinguished road
your cheapest easiest bet is the fuel filter, i have had many cars die while driving and changing the fuel filter was the fix. good luck.
chris
therippr is offline   Reply With Quote
Old 07-11-2009, 12:33 AM   #8
mrbean
it's actually a code 42. hmm...don't know what to do...
Old 07-13-2009, 05:24 AM   #9
pwpanas
Supra Owner
pwpanas's Avatar
Code 42 says:
"No. 1 Vehicle Speed Sensor Signal (for A/T) No. 1 Vehicle Speed Sensor Signal (for M/T)"
Looks like it's your speed sensor...or possibly a cracked solder joint in your odometer assembly (in the dash).
Old 07-17-2009, 08:24 PM   #10
mrbean
ya i was thinking about doing the odo splice and seeing what happens. i can't think of anything else....
At Full Engine Warm Up Engine Ildes Down And Sometimes Dies!!! RspecMKiii MKIII Supra 13 11-05-2009 01:56 AM
engine cuts and dies uddinf MKIII Supra 9 09-06-2009 06:56 AM
Start up and engine dies. Drag0na5h MKIII Supra 12 01-14-2007 02:04 AM
engine noise car dies after starting tex1116 MKIII Supra 7 11-18-2005 06:47 PM
