Old 05-13-2009, 01:42 PM   #1
m0t0xk1d
m0t0xk1d is on a distinguished road
is it possible? i was looking to get a supra but with prices so high of a twin turbo a was thinking of getting a non turbo. i was wondering if i could later but twin turbos on it or could i only put a single on it?
m0t0xk1d is offline   Reply With Quote
Old 05-14-2009, 12:15 AM   #2
Curtis
Curtis is on a distinguished road
Okay man, check the name of the engine, if its a 2jz-GE than its a non-turbo, meaning the supra is a downgrade. A GE engine will have high compression pistons, (which is a bad thing, turbos add alot of compession meaning you'd blow something) your also looking at changing your head, and alot of other stuff..
A 2jz-GTE (turbo engine) has completely different cylinder head, oil squirters to cool the pistons. The GTE supras also had better abs braking system, transmission, rear differential, ignition and starter, ecu, suspension, and more... The non-turbo version (GE) is a big downgrade, and your looking at alot of work and money to add turbo's to it.
IMO i'd save up for a turbo supra, or buy a cheap supra then buy an engine for it (2jz-gte).
Hope that helps.
they.call.me.curtis
Curtis is offline   Reply With Quote
Old 05-14-2009, 03:32 AM   #3
Yes, you can turbo it later (either twins or a single), but for twins you'd need to change the head. Like Curtis says, there'd be limits if you single turbo'd the 2jz-ge due to the higher compression pistons...probably about 400rwhp or so max. Even if you did all of this (including the fuel system and ignition systems you'd need to beef up to support this level), you'd still be way behind what you'd have with a full mkiv tt because of the braking system, the suspension, transmission, differential, etc., etc. In other words, the mkiv tt is a LOT more than just an n/a with turbos.
Old 05-13-2009, 01:42 PM   #4
m0t0xk1d
anything can be done with money , but yes u can do that but u may want to research some might be worth to spend the money now on a tt way better car to start
1jz-gte twin turbo conversion shane lynn Non-Generation Specific Questions 0 01-14-2006 09:00 AM
