Old 06-01-2009, 10:21 PM   #1
Javier Wilde
Javier Wilde is on a distinguished road
Default 1.5jz question.
First of all hello.
I got a toyota soarer 1jzgte, and i bought a 2jzge very cheap, and my question is can i put the 2jzge crankshaft, rods and 1jzgte pistons in my 1jzgte block, so i dont loose the squirters???.
Does anyone knows any link with that?.
Thanks alot.
Javier.
Javier Wilde is offline   Reply With Quote
Old 06-02-2009, 12:35 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Javier Wilde View Post
First of all hello.
Thanks alot.
Javier.
1) I don't know for sure, so please double-confirm elsewhere
2) I don't think you can do what you describe - from what I understand, the 1jz-gte is the same bore with a shorter stroke (which is why it's only 2.5L).
To me, you should consider doing it the other way...take your 2jz-ge block to a machinist and ask him to drill holes & tap boltholes for the 1jz-gte oil squirters.
Life begins at 30psi.
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
1.5jz question Javier Wilde MKIII Supra 0 06-02-2009 02:44 AM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
