#1 |
So after having my supra for a year, I want to take it to BPU. It is currently stock with a lowered bilstein suspension, fujitsubo exhaust and turbo timer. Does anyone have experience with going BPU with a JDM because I have heard some parts don't work on JDM. Is the following all I need as far as parts?
HKS Speed Delimiter TRD speedo Cold Air intake Hard pipes upgraded temp sensor wider rims and tires bigger brakes Any help appreciated! Thanks |
#2 | |
Supra Owner
![]() Quote:
You will need: - A way to limit fuel cut (in the us-spec, this is done with a GReddy BCC) - A downpipe to eliminate the oem catalytic converter - a way to raise the boost (the clamp-mod should work just fine).
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. |
#3 |
I need the speedo cause the stock one only goes to 180 km/h and after moving the 180 km/h speed limiter I will want to know how fast I am going above that. I agree with your reply although apparently the stock JDM fuel pump should be upgraded to a 255. The stock brakes were designed for 180km/h max I'm pretty sure so I want to go bigger for some more stopping power. I can't remember if theres a downpipe on it I will need to check.
#4 |
Ok so now I'm sitting with the option of going with
Greddy BCC HKS Speed Defender Aftermarker electronic boost controller or MAP ECU-2 Since my car is JDM and comes with a MAP sensor instead of MAF, it becomes a lot easier to install a MAP ECU-2 With either setup I am going to put a Greddy electronic boost gauge where the OEM clock is and replace the OEM 180km Speedo with a TRD 320km one. My biggest concern with going with a speed cut defender is that it tricks the ECU into thinking that you aren't going over limited speed where as the other method, the ECU knows how fast you are going and doesn't care. Does anyone have any comments with which setup to go with. |
#5 | |
Supra Owner
![]() Quote:
http://mkiv.supras.org.nz/techo.htm#SPEED_LIMITER
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 07-06-2009 at 03:47 PM. |
#6 |
Hiyas I also have a JDM 94 Supra , my recent mods are full 4inch custom exhaust , TRD speedo , c's short shifter , open air filter , race seats, aem tru boost controller , aem air fuel wide band gauge, K-sport 36way adj-coilovers.
Havent been able to install the AEM Tru boost controller since I don't know how to. Supra runs very strong and fast. As for the speed limiter , Ive just unpluged the trac fuse. works well , although you will get the trac light blinking all the time.. Let me know what brakes you decide on , I'm interested in upgrading mine to a big brake package, but I'm not sure if I'l have to upgrade the master also.. |
Planning on upgrading to 7M-GTE | bambam | MKIII Supra | 1 | 09-20-2007 02:14 AM |
Upgrading turbos on a 1jz | supradaddy0803 | MKIII Supra | 1 | 07-16-2007 10:08 PM |
upgrading intake and exhaust! | tone loc | MKIII Supra | 28 | 04-17-2007 06:57 PM |
upgrading my turbo | Supra4turbo20 | MKIII Supra | 6 | 01-20-2006 04:42 PM |
upgrading 1987 turbo | Prez420 | MKIII Supra | 22 | 09-24-2005 03:03 PM |
