Old 06-18-2009, 03:21 PM   #1
Durandal
Durandal's Avatar
Durandal is on a distinguished road
Default Help upgrading JDM to BPU
So after having my supra for a year, I want to take it to BPU. It is currently stock with a lowered bilstein suspension, fujitsubo exhaust and turbo timer. Does anyone have experience with going BPU with a JDM because I have heard some parts don't work on JDM. Is the following all I need as far as parts?
HKS Speed Delimiter
TRD speedo
Cold Air intake
Hard pipes
upgraded temp sensor
wider rims and tires
bigger brakes
Any help appreciated! Thanks
Durandal is offline   Reply With Quote
Old 06-19-2009, 11:07 PM   #2
HKS Speed Delimiter
TRD speedo
Cold Air intake
Hard pipes
bigger brakes
No speedo necessary for BPU. No cold air intake necessary for BPU. No hard pipes necessary for bpu. Bigger brakes not necessary for bpu.
You will need:
- A way to limit fuel cut (in the us-spec, this is done with a GReddy BCC)
- A downpipe to eliminate the oem catalytic converter
- a way to raise the boost (the clamp-mod should work just fine).
Old 06-21-2009, 11:30 PM   #3
Durandal
Durandal's Avatar
I need the speedo cause the stock one only goes to 180 km/h and after moving the 180 km/h speed limiter I will want to know how fast I am going above that. I agree with your reply although apparently the stock JDM fuel pump should be upgraded to a 255. The stock brakes were designed for 180km/h max I'm pretty sure so I want to go bigger for some more stopping power. I can't remember if theres a downpipe on it I will need to check.
Old 07-05-2009, 05:19 PM   #4
Durandal
Durandal's Avatar
Ok so now I'm sitting with the option of going with
Greddy BCC
HKS Speed Defender
Aftermarker electronic boost controller
or
MAP ECU-2
Since my car is JDM and comes with a MAP sensor instead of MAF, it becomes a lot easier to install a MAP ECU-2
With either setup I am going to put a Greddy electronic boost gauge where the OEM clock is and replace the OEM 180km Speedo with a TRD 320km one.
My biggest concern with going with a speed cut defender is that it tricks the ECU into thinking that you aren't going over limited speed where as the other method, the ECU knows how fast you are going and doesn't care.
Does anyone have any comments with which setup to go with.
Old 07-06-2009, 03:40 PM   #5
Greddy BCC
HKS Speed Defender
or
MAP ECU-2
With the US-spec, pulling the trac fuse also elminates speed cut. Unfortunately I don't have personal, first-hand experience using the HKS speed defender. There's a bit more info on this topic here:
http://mkiv.supras.org.nz/techo.htm#SPEED_LIMITER
Old 09-26-2009, 02:44 PM   #6
RZ-rix
RZ-rix is on a distinguished road
Default JDM Supra
Hiyas I also have a JDM 94 Supra , my recent mods are full 4inch custom exhaust , TRD speedo , c's short shifter , open air filter , race seats, aem tru boost controller , aem air fuel wide band gauge, K-sport 36way adj-coilovers.
Havent been able to install the AEM Tru boost controller since I don't know how to.
Supra runs very strong and fast.
As for the speed limiter , Ive just unpluged the trac fuse. works well , although you will get the trac light blinking all the time..
Let me know what brakes you decide on , I'm interested in upgrading mine to a big brake package, but I'm not sure if I'l have to upgrade the master also..
RZ-rix is offline   Reply With Quote
Old 09-26-2009, 07:04 PM   #7
Durandal
Durandal's Avatar
I installed a Greddy Emanage Ultimate and used it to remove the speed limiter and the boost cut. It also gave me a good platform to tune with if I want to add in some custom maps. I have a Tanabe 3" downpipe which I haven't installed yet. A Innovate Motorsports wideband which I haven't installed yet and a blitz SD boost meter which is installed and works great.
Old 09-26-2009, 08:31 PM   #8
RZ-rix
Sounds great , is the Greddy Emanage Ultimate good for tuning supras with big single turbo upgrades also??
Old 09-27-2009, 02:52 AM   #9
Durandal
Durandal's Avatar
I don't know, but you could probably find out on the euro supra forums, it is more popular there.
Old 09-27-2009, 01:56 PM   #10
It'll work, best suited for mid-size (67mm-72mm) turbo upgrades, not big ones (76mm-90mm).
Planning on upgrading to 7M-GTE bambam MKIII Supra 1 09-20-2007 02:14 AM
Upgrading turbos on a 1jz supradaddy0803 MKIII Supra 1 07-16-2007 10:08 PM
upgrading intake and exhaust! tone loc MKIII Supra 28 04-17-2007 06:57 PM
upgrading my turbo Supra4turbo20 MKIII Supra 6 01-20-2006 04:42 PM
upgrading 1987 turbo Prez420 MKIII Supra 22 09-24-2005 03:03 PM
