Old 07-02-2009, 12:44 AM   #1
krahs912
krahs912 is on a distinguished road
Default code 14(help)
i have a 95 supra tt with code 14, 35 it has a rolling idle and pings badly. any one seen this or have any idea what it could be? Thanks!
krahs912 is offline   Reply With Quote
Old 07-02-2009, 01:00 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
DTC No. Circuit Diag..______Trouble Code Detecting Condition______Trouble Area______________________________Normal Mode Test Mode Memory
14______Ignition Signal______No IGF signal to ECM for 4~7_____________· Open or short in IGF circuit from igniter to ECM___ON__________n/a_______Yes
_________________________consecutive IGT signals with______________· Igniter
_________________________engine speed less than 3,000 rpm._________· ECM
35______Turbo Pressure
________Sensor Circuit
Based on this info, my first guess is that the problem may be in your Supra's primary wiring harness. Has it been disconnected from the ecu recently? If so, it may need to be removed and re-seated.
Life begins at 30psi.
KS code, and no KS connector? Scionguy MKIII Supra 5 08-28-2008 08:15 PM
code 14 and 52 west_side_supra MKIII Supra 30 06-02-2008 05:04 PM
Where EXACTLY is the key code? finaltable MKIII Supra 6 08-12-2007 01:26 AM
getting wierd error code and need general advice please noredline MKIII Supra 7 10-01-2006 05:23 AM
Need help with Code 51 newtome Non-Generation Specific Questions 7 04-17-2006 06:06 PM
