Old 07-05-2009, 07:00 PM   #1
krahs912
krahs912 is on a distinguished road
Default lean running supra??
I Have 95 supra that runs lean and pings bad. have a Apex i AFC Neo Fuel Management on full rich made it better but still pings, just less.(93 octane) Idle is up and down. cant find any leaks in ic piping or any vacuum lines off. i think it suckin in unmertered air but cant find where. i did all these mods last year and car ran great till a month ago. car is adult drivin and only has 40k. any ideas???
Mods
greddy fmic
hks exhaust
Greddy Profec B Spec II Boost Controller
boost tuned down to 10psi (was runnin 16-17)
hks ssqv
krahs912 is offline   Reply With Quote
Old 07-06-2009, 03:49 PM   #2
Mods
greddy fmic
hks exhaust
hks ssqv
Imho, step 1 is to bypass the AFC and see if it still has the problem. Also check the vacuum line going from the plenum to the oem FPR (fuel pressure regulator). Lastly, if those suggestions don't help, you'll need to do a boost leak check by pressurizing your charge-air system.
turbo? Knock sensor? running lean? west_side_supra MKIII Supra 19 02-01-2009 07:28 AM
MKIV Supra TT Daytime Running Lights?? MIX MKIV Supra 2 08-30-2007 02:52 AM
supra running rough finn MKIII Supra 0 09-25-2006 07:10 PM
87 Toy Supra N/A, Running on 4 Cylinders wilvelas MKIII Supra 5 04-24-2006 02:40 AM
