Old 08-13-2009, 01:23 AM   #1
krahs912
krahs912 is on a distinguished road
Default high speed(rpm) engine cuts out??? help!!!
Mods
Apex i AFC Neo Fuel Management
greddy fmic
hks exhaust
Greddy Profec B Spec II Boost Controller
hks ssqv
all mods were done last year on stock 40k supra and car ran great!
i have a 95 supra tt the engine cuts out in 3rd-4th gear,5000 rpm and up, 17psi of boost. have code 34. seems to be boost related as soon as i get 17psi there is a mometery cutout. not a miss or skip. engine stops and comes back. not sure if it fuel or spark. i cannot turn boost down. i disconnected Spec II and still get 17-18 peek psi of boost 3rd- 4th gear, seems high with no controller? car runs great in 1st-2nd gear only gets to 13-15 psi. wideband shows rich at all rpms,(not to rich) plugs look good gaped at .025 tested turbo actuator moves freely with 15psi of pressure. only has about a 1/2 in if travel but it does move freely. is that enought? if it was the fuel cut off in the ecm, wouldnt the engine shut down till the key was cycled and started? timing belt jumped 2 teeth 2 months ago put new belt,tentioner,and idler all toyota parts. dont think its related but thought i should mention it. this cut out problem did come at same time. im stumped please help want to go fast again!! THANKS
krahs912 is offline   Reply With Quote
Old 08-13-2009, 09:37 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by krahs912 View Post
Mods
greddy fmic
hks exhaust
hks ssqv
What are you running to eliminate the oem fuel cut - a GReddy BCC?
Life begins at 30psi.
Old 08-13-2009, 11:13 PM   #3
krahs912
im useing Apex i AFC Neo Fuel Management i checked fuel pressure today and it does not drop off at high rpm. (fp 50psi) i did find today that the boost goes from 17psi to 10psi when the problem happens so i think i am feeling a power loss. what could cause such a boost drop? it is a instintanious drop and comes right back. its like a switch. i can run 18psi in 1st and 2nd gear no prob. i think it has to do with holding boost for longer periods of time. thanks for any help you can provide.
Old 08-14-2009, 11:21 AM   #4
pwpanas
Supra Owner
pwpanas's Avatar
Does the Apex i AFC Neo Fuel Management unit have a provision to eliminate the fuel-cut in the 2jz-gte oem ecu (i.e. eliminating the need for a GReddy BCC or HKS FCD)?
The boost drop could be caused by a loose or split intercooler hose - it may overlap enough to hold 10psi, but push apart at levels higher than that. Another may be an improperly-functioning BOV.
Engine cuts out igosaur MKIII Supra 9 02-07-2019 07:09 PM
engine cuts and dies uddinf MKIII Supra 9 09-06-2009 06:56 AM
Question about Slick 50 engine protection! 88 MARK3 Non-Generation Specific Questions 15 07-15-2006 04:04 PM
