-   MKIV Supra (http://www.toyota-supra.info/forums/mkiv-supra/)
-   -   W58 Transmission no reverse (http://www.toyota-supra.info/forums/mkiv-supra/14872-w58-transmission-no-reverse.html)
serpentkilla 09-20-2009 12:10 PM
I have a 2jzgte swapped starion, i swapped the external shifter for a internal one. It's not going into reverse, i'm not sure if it was this way when i got it. It shifts fine in the other gears but not reverse. What do u think my problem could be?
pwpanas 09-20-2009 02:29 PM
Unfortunately, I've never rebuilt a W58 (mine's a 6spd). I know we have several very knowledgeable MKIII folks that might have W58 experience. I'd suggest adding a post to that forum as well in case someone there has an answer:
http://www.toyota-supra.info/forums/mkiii-supra/
serpentkilla 09-26-2009 02:39 PM
thanks, i started a thread there.
