Old 08-14-2005, 07:46 AM   #1
dxbsuperstar
Guest
Posts: n/a
anyone knows how to adjust this type of Bov for 13 psi max twinturbo 2jz gte vvti?????
http://cgi.ebay.com/ebaymotors/GREDDY-STYL...bayphotohosting
Old 08-14-2005, 03:53 PM   #2
whitetiger777
whitetiger777's Avatar
whitetiger777 is on a distinguished road
Actulay you don't use a blow off valve to regulate psi. All a BOV does is let the pressure escape from the intercooler piping when the throttle boddy cloeses. If the pressure does not escape it will travel back to the turbo causeing it to spin backward and put unkneeded stress on the turbo. If you want to controll boost you need a boost controller, either electric or manual.
whitetiger777 is offline   Reply With Quote
Old 08-15-2005, 04:50 AM   #3
Poodles
Poodles is on a distinguished road
Wastegate is what controls the PSI, you'll have to either shim the spring, or get a boost controller either manual or electronic.
Poodles is offline   Reply With Quote
Old 08-18-2005, 07:50 PM   #4
daiagaru2
daiagaru2 is on a distinguished road
get a boost contoler.
daiagaru2 is offline   Reply With Quote
Old 08-18-2005, 08:12 PM   #5
SupraMan1784
SP58GT
get either a waste gate or a manual boost controller
Now: Saving for an MKIV
Broken Rides:
valve cover gasket question? sevenmgte MKIII Supra 8 10-01-2008 06:02 AM
Adjusting Valve Shims Chambers MKIII Supra 6 02-09-2008 07:37 AM
egr valve... reusable? sd88supra MKIII Supra 3 06-22-2007 06:28 AM
Valve stem seals? Kuban MKIII Supra 9 03-27-2007 02:32 AM
Blowoff valve! 2JZEFINI-17 MKIII Supra 0 11-02-2006 02:13 AM
