Old 12-07-2009, 10:14 PM   #1
blackdemon93
blackdemon93 is on a distinguished road
Default converting a n/a to vvti turbo
i am converting a 93.5 toyota supra to a jdm vvti aristo swap.
i did this before on another supra which wasnt the vvti engine and didnt run into any problems. Well here is my problem i when i sit the engine in the bay the motor is twisted.
i used the n/a mounts and brackets, any advice will be helpful im going crazy!!
blackdemon93 is offline   Reply With Quote
Old 12-07-2009, 10:15 PM   #2
blackdemon93
sorry here are the pics.
http://s868.photobucket.com/albums/a...2.jpg&newest=1
http://s868.photobucket.com/albums/a...1.jpg&newest=1
Old 12-08-2009, 02:02 PM   #3
pwpanas
Supra Owner
pwpanas's Avatar
Have you tried the Aristo mounts? Worst case you may need to get a custom mount fabbed. If the Aristo mounts don't work, I'd recommend you pull the vvti engine and carefully measure it's mount locations and compare those measurements to the n/a 2jz-ge mount locations. Wish I could be of more help, but I haven't done this swap myself.
Please keep us informed - post back here when you've found or made something that works. Thanks in advance!
Life begins at 30psi.
Converting NA to Bostlogic stage 1 turbo. need help amin MKIV Supra 5 09-26-2007 01:19 AM
