-   MKIV Supra (http://www.toyota-supra.info/forums/mkiv-supra/)
-   -   Headlight Dim (http://www.toyota-supra.info/forums/mkiv-supra/16048-headlight-dim.html)
MalumInSe 02-10-2010 06:52 PM
Headlight Dim
Drivers side headlight is dim. I switched the driver and passenger side bulb and get the same result - so I know it isn't the bulb.
I don't have a wiring diagram available so was wondering if anyone else has encountered this issue. Is it possibly a bad ground for the drivers side headlight wiring?
paster120 03-09-2010 11:18 AM
One dim head light
Hi i had the same problem,and it turned out to be a fuse in the engine bay
