Old 02-16-2010, 07:30 AM   #1
cobz
cobz is on a distinguished road
Default O/D light flashing + Engine light on after 80km/h.
Pretty much what the thread title says.
I have a 94 Supra and the O/D light will begin to flash after about 5 mins of normal driving. Never goes away. Searched around forums and it MIGHT be the Speed Sensor or something like that.
Secondly;
If I take off from a slow speed and accellerate all the way through 80km/h as soon as the car changes into 3rd what appears to be a little orange engine light appears and does not go away until I switch the car off.
I want to check the ECU, because that's what I have been told to do, but I cant find it.
Any solutions to these problems and also point me in the right direction to find the ECU please?
cobz is offline   Reply With Quote
Old 02-17-2010, 03:37 AM   #2
If it's anything like a MKIII it's an error found through the transmission's ECT.
I'm going to move your thread to the MKIV section where it will hopefully get better response.
Old 02-18-2010, 03:19 AM   #3
Secondly;
Here are directions for checking the ecu codes:
http://www.mkiv.com/techarticles/eng...bd1_codes.html
Old 02-18-2010, 04:23 AM   #4
cobz
Yeah, I have been directed to that Site in the past, but I do not know where that actual unit is? Like, where are these terminals to connect?
Old 02-19-2010, 02:33 AM   #5
The OBD port is on the bottom front edge of the dash between the steering column and door.
Tags
engine light, o/d light
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
check engine light & bulb light, what? nosuprayou MKIII Supra 2 12-19-2009 09:15 PM
Engine light and warning light on. Chomper MKIV Supra 11 07-18-2008 11:44 AM
Engine Light Supra91_ishot Non-Generation Specific Questions 2 06-08-2005 12:37 PM
