pwpanas |
02-18-2010 02:39 AM |
Originally Posted by MDT
(Post 78942)
The supra in question is a 93.5 premeir edition twin turbo my car has 65000 mi on it and I need a new clutch and am wondering what is my best option for pefomance keeping in mind this car is stock and i have no plans to sup it up owned it for 15 yrs. thanks for any help
Simple/quick answer: The stock clutch would be just fine for your application.
More info, if you're interested: If you go with any 'performance' clutch that's relatively affordable, it'll be a single-disk clutch with a much stiffer pedal pressure. This will make your Supra more difficult to drive - your left leg may actually tire from the stress during a long commute, and you're more likely to stall your car or chirp the tires leaving a stop sign or red light. If you want to spend a lot for a clutch (~$2k USD+), then there are other choices that you theoretically might consider.
Question: How important is 'normal'-feeling driveability to you?
