Old 03-27-2010, 07:35 PM   #1
matt1993supraTT
matt1993supraTT's Avatar
matt1993supraTT is on a distinguished road
Default car dies under boost
got a 93 singal turbo supra when it starts building boost ( which is about 4000) it just dies! i have no idea what it is.. really need some help from the supra gurus
matt1993supraTT is offline   Reply With Quote
Old 03-28-2010, 01:14 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
What is your air:fuel ratio when it dies?
Please tell us more about your car (i.e. list all modifications):
Life begins at 30psi.
Old 03-28-2010, 01:22 AM   #3
matt1993supraTT
the a/r's stay around 12.9 before it dies, its a singal turbo 50mm waste gate stock computer 750cc injectors 255 walbro adjustable FPR and cam gears with the exhaust cam retarded 4 degrees, the guy thinks a AEM will slove his problems but i cant give him a clear answer about, another thing that strikes me as off the maf is on the intake side inline with the intercooler pipes crazy! its also missing most of its sensors that where on the intake
Old 03-28-2010, 02:16 PM   #4
pwpanas
Supra Owner
pwpanas's Avatar
the a/r's (did you mean a/f's?) stay around 12.9 before it dies, its a singal turbo 50mm waste gate stock computer 750cc injectors 255 walbro adjustable FPR and cam gears with the exhaust cam retarded 4 degrees, the guy thinks a AEM will slove his problems but i cant give him a clear answer about, another thing that strikes me as off the maf is on the intake side inline with the intercooler pipes crazy! its also missing most of its sensors that where on the intake
Which guy? The owner? Is he paying you to work on his Supra?
I agree the maf configuration needs to be changed back to oem - this is a strong suspect as the first troubleshooting step to take. Although an AEM might fix the problem, that's like fixing a cut in your finger by replacing your arm with a robotic prosthetic. A whole AEM setup is $2500+, and this could likely be fixed with a few hours (or less) of troubleshooting with the existing setup.
Old 03-28-2010, 04:39 PM   #5
matt1993supraTT
yes the owner he's my best bud no money just help him out mybe i'll get a 6-pack of budlight lol it looks like a DSM setup with the maf like a blowthru he wants the AEM pretty bad i agreed that the AEM would give him a boost of performance! i hooked up the computer to the car and it pulled 5 codes fuel pump relay, coolant temp sensor, TPS sensor, and turbo boost pressure sensor *2
Old 03-28-2010, 09:59 PM   #6
pwpanas
Supra Owner
pwpanas's Avatar
Actually, the AEM might not give him a great boost of performance. What size of turbo is it?
The coolant temp sensor problem needs to be fixed; it's even needed with the AEM.
Either the Throttle Position Sensor and the Turbo Pressor Sensor could be a part of the stalling problem, so they should be corrected as well.
Troubleshooting steps for these sensors are all in the TSRM (Toyota Supra Repair Manual). If your buddy doesn't already have one for his Supra, he needs to get one.
low boost psi, wtf supradad86_5 MKIII Supra 4 02-09-2014 02:05 AM
boost hits, cars dies chillin943 MKIII Supra 10 08-19-2009 05:46 PM
wont hold boost Supraman MKIII Supra 12 04-19-2007 04:52 AM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
No boost in neutral but boost in gear! edgardo MKIII Supra 5 10-09-2004 04:01 AM
