-   MKIV Supra (http://www.toyota-supra.info/forums/mkiv-supra/)
-   -   running rich (http://www.toyota-supra.info/forums/mkiv-supra/1661-running-rich.html)
egge21 08-27-2005 05:27 AM
hey my non turbo supra is running rich and has a rough idle. Would the problem be the coolant sensor or the oxygen sensor?
SupraMan1784 08-28-2005 05:04 PM
probably the oyxgen sensor....either that or its your maf
92supra 08-28-2005 09:32 PM
its always good to make sure the throttle bodies are clean, as this was the same case for a friend of mine.its still not perfect but it may need a ecu remapping. in your case im not to sure but i felt it would help giving my account of it. ;)
