Old 04-21-2010, 10:29 PM   #11
matt1993supraTT
matt1993supraTT's Avatar
matt1993supraTT is on a distinguished road
What makes you think I haven't done it? I listed exactly what you need, in addition to the v160 and 2jz-gte: harness, ignitor, resistor pack, and ecu. You say you've already got the intercooler covered (aftermarket?). Oh, and you'll also need a different or custom driveshaft unless you also plan to swap your n/a diff with a TT diff. Of course, the exhaust setup is different from the n/a so you'll need an aftermarket (catless) downpipe or an oem downpipe (with cat) to hook up to the oem egcv housing.
Where are you getting the 2jz-gte? If it's from a Japanese engine dealer, it'll likely be from an Aristo, which means the oil pan will need to be changed (you can use the one from your 2jz-ge). It's a LOT of work getting the oil pan completely clean before applying the new gasket material because the upper oil pan is aluminum and there are narrow grooves you have to clean out - of course a steel brush or wire wheel will take aluminum off too, which is why the job is so cumbersome.
However, note that this swap won't produce a full TT Supra. For example, the abs braking system on the n/a is significantly inferior to the tt's.
Lastly, please note that you can't stop folks from posting - especially if the info they have to share is relevant. However, you do have the power to ignore anyone's posts, and wait for someone else to post who has better info for you.
Peace, and best of luck.
amen brother!
matt1993supraTT is offline   Reply With Quote
Old 04-22-2010, 02:41 AM   #12
93.5_JDM_MK4
93.5_JDM_MK4 is on a distinguished road
The place where iam getting this is from a jap parts dealer, but engine is from a tt supra. The package includes everything from the engine and all that goes with it, tranny, diff and rear subframe. I plan on upgrading the braking system at a later date so the TT abs system doesnt really interest me anyways. Thanks alot for trying to help me but again i wanted to know if there was any suprises or wiring issues to worry about, the rest im pretty well informed about. Sorry if i offended you with my last post but it just seemed as though noone really had info that could be useful to me, i dont see the use in posting things like ''never seen it done'' and ''seems difficult''...
93.5_JDM_MK4 is offline   Reply With Quote
Old 04-22-2010, 09:01 PM   #13
matt1993supraTT
well i am sorry that my information did not help you either but i will give you a bit of useful info sell the n/a car and buy a TT then you would'nt have to worry about swapping anything to begin with. sounds like you have the money to do so, cant be cheap importing a jdm supra engine. buying a imported engine with the whole drivetran never heard nor seen that! hope this helps
Old 04-23-2010, 03:37 AM   #14
93.5_JDM_MK4
well as a matter of fact instead of costing me 20,000$ for a stock TT, its going to cost me about 14,000$ after its swapped. I also like the fact that not many people have done this, thats why i want to do it!
Old 04-23-2010, 03:42 AM   #15
93.5_JDM_MK4
and if u dont believe me about the drivetrain being included, check this site out :
http://www.japanpowerinc.com/engine_...Toyota_2JZ_GTE
this place is roughly 4 hours from where i live.
Old 04-24-2010, 09:42 PM   #16
pwpanas
Supra Owner
pwpanas's Avatar
If your n/a is US-spec (LHD), and the harness is Japanese-spec (RHD), it won't work.
P.S. I never posted "never seen it done" or "seems difficult...
Life begins at 30psi.
Old 04-24-2010, 10:52 PM   #17
matt1993supraTT
dude i paid 12K for mine it was a one owner car. man more power to you if you want to swap the motor still but theres got to be some reason why everybody has'nt swapped a TT engine into a n/a if it was easy..
Old 04-24-2010, 10:53 PM   #18
matt1993supraTT
he's talking about me
Old 04-25-2010, 02:46 AM   #19
pwpanas
Supra Owner
pwpanas's Avatar
I believe you're correct, but he also acted like I said something like that too, when he said to me "why are you even posting replies if your not someone whos already done this?" when he responded to my post here:
How do you know it's not complicated? I agree with Matt - at a minimum you'll need a whole new primary wiring harness, ecu, ignitor, and resistor pack. While perhaps one might consider this not to be "complicated", it won't be cheap...
Either way, no biggie. It seems all straightened out now...
Old 05-26-2010, 11:53 AM   #20
93.5_JDM_MK4
i was also wondering about putting a aristo engine in (front sump), if anyone knows the modifications needed for it to go in a supra...?
2JZGE Swap....not 2JZ-GTE AlexSchuSupra MKIII Supra 1 10-31-2009 11:09 PM
***Need expert advice on a 2JZGTE swap in a Lexus*** sixfourbolt Non-Generation Specific Questions 4 08-27-2006 08:30 PM
2jzgte 2jzge zbower Non-Generation Specific Questions 1 06-19-2006 10:14 PM
NA->T swap and convertion questions 5+4=9 MKIII Supra 6 03-02-2006 02:11 AM
