Old 04-26-2010, 07:41 PM   #1
D_DAWG84
D_DAWG84 is on a distinguished road
Hey question for all you supra lovers.... I have a 93 5-speed na supra jdm with 90.000km on it pretty mint I have a chance to trade mine for a 93 jdm tt six speed supra with 141.000km witch is more then mine.... My car and 5k Canadian for the trade... The tt is not a fresh as mine it has a blitz intercooler aftermarkett intake blow off valve turbo timer.... Is that too many km or am i geting a ok deal?????Plz let me know.....
hi there all u supra lovers I own a 93 JDM NA 5-speed supra... It has 93.000km on it absolutly mint... I have a chance to trade for a 93 JDM 6-speed tt supra same colour with 141.000km on her.. My car and 5.000$$ Canadian... The tt is not in the same shape as mine still pretty good though just needs a good detail. It has a blitz intercooler blow off valve full custom exaust turbo timer etc.. How many km will a 2jz gte run with out problems from higher milage???? I have driven the car love the power big step up from my GE please let me know what u think if its a good deal thanks alot for your advise.....
Danny,
Vancouver BC
D_DAWG84 is offline   Reply With Quote
Old 04-28-2010, 12:43 AM   #2
Thread moved to the MKIV section. Please try to post in the most relevant section.
Moved to the MKIV section.
Old 04-28-2010, 02:13 PM   #3
pwpanas
Supra Owner
pwpanas's Avatar
Danny,
Vancouver BC
An unmodified Mkiv TT can run reliably to 200,000 miles or more if well-maintained and unmodified. The "etc." in your description of modifications has me worried though. In general, it's a good plan, but maintenance and quality of modifications are key to reliability.
Note: Threads merged - why did you double-post your question?
Life begins at 30psi.
Old 04-28-2010, 04:22 PM   #4
D_DAWG84
ok thanks I will find out what else is done to the car I guess I can always rebuild the engine to handle big hp if it pops.. What about the drive train and gearbox??? Will they need a rebuild aroung 200.000miles????
Old 04-28-2010, 07:58 PM   #5
pwpanas
Supra Owner
pwpanas's Avatar
The engine won't "pop" unless you try increasing the boost without running any race fuel. The oem 2jz-gte is a rock.
With proper maintenance, the 6spd transmission and oem tt diff won't need a rebuild around 200K miles unless they've been abused or poorly maintained. Minor items may need to be replaced however (eg. new oil seals).
Old 04-28-2010, 09:07 PM   #6
D_DAWG84
The engine won't "pop" unless you try increasing the boost without running race fuel. The oem 2jz-gte is a rock.
nice man thanks for the info.. Im excited about the tt such a bad ass car so much pull then my ge......
Old 05-05-2010, 11:34 PM   #7
pwpanas
Supra Owner
pwpanas's Avatar
...With proper maintenance, the 6spd transmission and oem tt diff won't need a rebuild around 200K miles unless they've been abused or poorly maintained. Minor items may need to be replaced however (eg. new oil seals).
Note - it's fairly common for the seal around the shift shaft to leak. The usual fix is to (carefully!!!) remove the leaking one, and then replace it with two brand-new oem seals (yes, there is room for two). The seal removal is tricky because the tranny case is aluminum - any tool tough enough to hook the seal and pull it out could easily scratch the bore (which would lead to leakage even with a new seal). If you're interested, the tool I made to do this job was a tiny, flattened hook that I slid on the inside of the seal, between the shift shaft and the seal. Pulling in this part of the seal only kept the hook far away from the aluminum. Also note that this fix is pretty much only for the more anal-retentive Supra owners - the shift shaft is at the top of the tranny, so it doesn't leak much at all from that point (just enough to put a layer of dust on that part of the tranny).
JDM SUPRA RZ 6speed. Question? MKIV MKIV Supra 4 10-09-2009 04:55 PM
SUPRA LSDs AND COLD AIR INTAKEs QUESTION C0o0n Non-Generation Specific Questions 2 08-10-2008 02:33 AM
Toyota Supra Engine Question l_o_t_s_r MKIV Supra 33 08-30-2007 02:29 AM
Not a Supra, but could act like one. Need advise. blaze the chemi Non-Generation Specific Questions 6 03-01-2007 07:30 PM
