Old 05-13-2010, 03:11 PM   #1
rmerrell
rmerrell is on a distinguished road
Default Fuel Pulsation Dampener Mod
Does anyone know how long the fuel line has to be for this mod. About to run out and get a new fuel filter and pick up the line later this afternoon and on the mkiv.com page it does not say how long the line needs to be. Just wondering if anyone here knows.. Looks like 24" or so under the car but I want to make sure..
rmerrell is offline   Reply With Quote
Old 05-14-2010, 01:51 AM   #2
Yep 24" will work (assuming you use all the right fittings).
No Fuel Pressure Wong Wei MKIII Supra 6 05-16-2010 03:03 AM
fuel pump mounting bracket GremlinMKIII MKIII Supra 4 09-06-2007 07:08 AM
