Old 06-08-2010, 06:50 AM   #1
mrgdm007
mrgdm007 is on a distinguished road
Default Boosting an MK4
Hey so I had a quick question, with bpu parts on a 94 supra with stock tt's, 6speed, and stock intercooler, my question is, is 14,15 psi safe with the stock intercooler on 93 octane and what kind of hp will I be looking at with bpu mods at these boost levels thanks in advance!
mrgdm007 is offline   Reply With Quote
Old 06-08-2010, 03:21 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
How many miles are on your turbos? Have you done a compression test? If I can get your mileage and compression numbers, it'll be easier to give you a good answer to your question.
16psi is safe* with fresh 93 (r+m)/2 octane fuel with the oem ecu, but no more. 17psi+ will slowly but surely damage the engine and reduce compression.
*Disclaimer: Ymmv
Life begins at 30psi.
Old 06-08-2010, 03:35 PM   #3
mrgdm007
It has 107,000 miles on it I'm not sure on compression but it drives great, was never beatin on it pulls very strong , no turbo smoking or anything like that. If you could give me just a ball park average until I get compression tested but what I'm mainly concerned about the psi my stock intercooler can take than how much hp I'm getting
Old 06-09-2010, 04:00 AM   #4
pwpanas
Supra Owner
pwpanas's Avatar
Ballpark average for a bpu mkiv tt at 15 or 16psi is 350rwhp (= 412hp at the crank) or so.
The stock SMIC can easily take 15 or 16 psi. Although the end-tanks are plasic, you could hold them on with a metal tie-down strap if you had to (it's been tried and it works - but only necessary at 20psi+ on race fuel).
Tags
boost, bpu, horsepower, mods, psi
weird boosting? supraluver4life MKIII Supra 11 02-08-2010 04:36 PM
constant boosting problem supranutz MKIII Supra 4 12-06-2009 02:57 PM
Boosting my 88 7mge lemonhead4696 Non-Generation Specific Questions 5 07-02-2008 02:24 AM
Safe boosting for na-t supraman121 MKIII Supra 0 01-06-2007 08:13 PM
boosting turbo steve119md MKIII Supra 2 09-15-2005 11:09 AM
