Old 08-10-2010, 06:06 PM   #1
TurboSupera
TurboSupera is on a distinguished road
Default Stock amp.
I was tearing the car apart this weekend to see why the quasi "sub-woofer" in the trunk was not working and realized that the two speaker wires were cut. I then tested the wires by hooking it up to another small speaker and nothing, so then I tested the wires with a volt meter and nothing. Anyway to make a long story short....does anyone know what all the wires from the stock amp (located under the passenger seat) are? I thought it was just to power the quasi "sub-woofer". I took out the amp and everything still works. Do the amps typically go out and are there any internal fuses that may have blown. I took the amp apart but didn't see any fuses or anything that looked like it burnt out? Any ideas will be greatly appreciated.
TurboSupera is offline   Reply With Quote
Old 08-14-2010, 02:05 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
http://www.mkiv.com/manual/1995_elec...ual/index.html
http://www.mkiv.com/manual/1995_elec...95elec_214.JPG
etc...
Life begins at 30psi.
7M-GTE Head torques on stock bolts... MA70-3.0GT MKIII Supra 2 11-07-2009 04:58 PM
Boost and Stock Fuel collink MKIII Supra 5 03-26-2008 11:43 PM
